| View previous topic :: View next topic |
| Author |
AC Encoder active prototype/DC coupled booster update |
os Ultra Wiggler
Posted: Sat May 08, 2010 5:13 am Post subject: AC Encoder active prototype/DC coupled booster update |
Just wanted to give an update and share my plans.
The previously published circuit, while it works, has some drawbacks. Mostly these come down to the need for rewiring to cope best with various possible inputs e.g. balanced, ground-referenced balanced, unbalanced, DC-coupled balanced etc.
I'm working on a much improved version, which has none of these drawbacks. All that will be required is a jumper to select between DC-coupled and AC-coupled - all other input types will be handled with no changes.
My plan is to build an 8-way version of this, and make it available in various versions e.g.
- PCB only
- assembled PCB to be inserted in your choice of module
- fully assembled module with TRS jack inputs
- fully assembled module with D Sub input
Largely because of the turnaround times on PCB manufacture, this is all a good number of weeks away. I'll post again nearer the time to gauge interest. The more I make, the cheaper it will be, but I don't want to be left with a lot of inventory. _________________ http://www.expert-sleepers.co.uk/
http://twitter.com/expertsleepers
http://www.darkroomtheband.net/ |
| Back to top |
bsmith Ultra Wiggler
Joined: 07 Jan 2010 Last Visit: 02 Sep 2010 Posts: 762 Location: Dallas
Posted: Sat May 08, 2010 8:14 am Post subject: |
| This sounds so great, I'll go for the assembled D Sub myself. Got any panel design ideas to show us? |
| Back to top |
os Ultra Wiggler
| Back to top |
os Ultra Wiggler
Posted: Sat May 08, 2010 11:44 am Post subject: |
OK, a question for you then. First, two points:
- This module will do away with the need for special 'floating ring' cables, will work with the AC Encoder, and will give you a much greater voltage output than an audio interface by itself.
- 8 custom made 'Volta cables' from Sly Goose will cost you about $100.
So the question is, how much would you pay for the module? _________________ http://www.expert-sleepers.co.uk/
| Back to top |
baltimoroder Common Wiggler
Joined: 27 Feb 2010 Last Visit: 02 Sep 2010 Posts: 145
Posted: Sat May 08, 2010 3:15 pm Post subject: |
It seems $200 is the upper limit people are willing to pay for "utility" modules. But it's hard to say how much an AC Encoder module is actually _worth_ as there really isn't anything like this out there... Anything that makes noise is a potential CV source. No special hardware, no special cables, output voltages biased to Doepfer standards. The mind wiggles with possibilities.
FWIW: Expert Sleepers pricing in general is a great value. Am sure you'll sell a ton.  |
| Back to top |
Analog>Plugins Common Wiggler
 Posts: 234 Location: Uk
Posted: Sun May 09, 2010 10:49 am Post subject: |
I personally would pay £100 for a finished ready to go module.
Does this new system cause any lag in the voltage change or is it just as instant as a normal dc coupled device? |
| Back to top |
mono-poly Le Cheff
 Posts: 3274 Location: netherlands
Posted: Sun May 09, 2010 10:59 am Post subject: |
Are you gonna do versions for with the iphone to?
Love to see a standalone little box. _________________ i don't need the gear, the gear needs me
http://mono-poly.blogspot.com |
| Back to top |
os Ultra Wiggler
Posted: Sun May 09, 2010 1:23 pm Post subject: |
@Analog>Plugins - I've been doing the sums, and £100/$160 is a realistic price, if I'm doing these in quite short batches initially.
There's no lag in the module when DC-coupled - when AC-coupled, it's the usual extremely small slew.
@mono-poly - Not initially. The trouble with standalone boxes is power. It's one more complication to worry about. With Eurorack I can relax in the knowledge that it's +/-12V wherever in the world the module is used. _________________ http://www.expert-sleepers.co.uk/
| Back to top |
os Ultra Wiggler
| Back to top |
mr chombee Learning to Wiggle
Joined: 23 Sep 2009 Last Visit: 02 Sep 2010 Posts: 28 Location: Berlin
Posted: Mon May 10, 2010 6:43 am Post subject: |
| Nice! I'd pay £100 for a finished module, too. |
| Back to top |
Posted: Mon May 10, 2010 6:53 am Post subject: |
| Has anybody seen D Sub snake that is angled (elbow) on the 25 pin end? May be nice for tidiness if that thick cable wasn't coming straight out of the rack - only drawback i see to the d sub route. I guess if there is such a thing as a D Sub with an elbow there'd be 2 versions of it, angled this way or that way since the pinout is asymmetrical 12 13... |
| Back to top |
os Ultra Wiggler
| Back to top |
Posted: Mon May 10, 2010 7:14 am Post subject: |
| os wrote: | | The neatest option, if this was going to be installed long-term in a rack, would be to run the D Sub connector out the back - leaving just a small panel with 8x 3.5mm jacks on the front. |
Totally. But aren't many (most?) manufactured racks closed up with no access for running cable in this manner? My rack which is being built can have access through the rack rear, but seems like you'd want a version that did have the D Sub cnnection on the front for those that don't, like the monorocket stuff, etc... |
| Back to top |
os Ultra Wiggler
| Back to top |
Arnoid Learning to Wiggle
Joined: 25 Jan 2010 Last Visit: 20 Jul 2010 Posts: 16 Location: Belgium
| Back to top |
goiks Hardest Tryer
 Posts: 824 Location: bishop california
Posted: Mon May 10, 2010 1:35 pm Post subject: |
| os wrote: | | £100/$160 is a realistic price, if I'm doing these in quite short batches initially. |
this sounds fair to me. |
| Back to top |
Posted: Mon May 10, 2010 1:39 pm Post subject: |
| goiks wrote: | | os wrote: | | £100/$160 is a realistic price, if I'm doing these in quite short batches initially. |
+1  |
| Back to top |
os Ultra Wiggler
| Back to top |
wxyz Learning to Wiggle
Joined: 14 Apr 2010 Last Visit: 02 Sep 2010 Posts: 22
Posted: Wed May 12, 2010 8:33 pm Post subject: |
| i'm up for one |
| Back to top |
suthnear Common Wiggler
 Posts: 166 Location: located
Posted: Thu May 13, 2010 3:14 pm Post subject: |
os, a question: is there any possibility that some of the connections could be dc and some ac? I'm mostly interested in AC, but I wouldn't mind just connecting 2 of my nord g2's ac coupled outs to the same board. Obviously, this is a ridiculously specific requirement, but it never hurts to ask
I'm interested in this regardless, though. |
| Back to top |
