Author |
Power cable question |
br>pugix |
br>I'm planning on putting two DIY boards behind one panel. I use the 4-pin MOTM power connector to connect the supply. I was wondering if the Power Cable 6P-6P can be used to run power from one Mattson board to the other. br> br> |
br>mmm |
br> pugix wrote: | I'm planning on putting two DIY boards behind one panel. I use the 4-pin MOTM power connector to connect the supply. I was wondering if the Power Cable 6P-6P can be used to run power from one Mattson board to the other. |
Absolutely. br> br> |
br>pugix |
br>I ordered a couple of 6P-6P cables! Thanks.
Now I see the advantage to having both types of power connector on each board. br> br> |
br>mmm |
br> pugix wrote: | I ordered a couple of 6P-6P cables! Thanks.
Now I see the advantage to having both types of power connector on each board. |
br> br> |
