Eurorack Travel Case - Buchla Easel - Videos
A place to post links to your music, upload tracks and promote yourself.
Moderators: ignatius, Kent, Joe., analogdigital, infradead, lisa, parasitk, plord
Anechoic
Post by Anechoic » Fri Aug 05, 2016 10:37 am
New Vimeo videos / SoundCloud tracks regularly added.
Follow me on Instagram:
My Instagram
SoundCloud playlist
Eurorack travel case and Buchla Easel performance videos. Recorded live in one take.
Watch “Venchy” on Vimeo
Watch “March Cover” on Vimeo
Watch “Neap” on Vimeo
Watch “Berth” on Vimeo
Watch “Aksis” on Vimeo
Watch “Levox” on Vimeo
Watch “Low Voltage” on Vimeo
Watch “Valeas” on Vimeo
Watch “Agral” on Vimeo
Watch “Ninnana” on Vimeo
Main sequence was first recorded into Antimatter Brainseed from Qu-bit Octone, then played back with some realtime knob tweaking.
Watch “Ferfin” on Vimeo
Watch “Seeding” on Vimeo
More detailed patch description at Vimeo, and more modular tracks at Soundcloud
http://soundcloud.com/giorgioalvera/set ... co-modular
PHOBoSapiens
Post by PHOBoSapiens » Fri Aug 05, 2016 2:58 pm
lovely :love:
"My perf, it's full of holes!"
Anechoic
Post by Anechoic » Fri Aug 05, 2016 8:52 pm
Thanks. In fact I was pleased to finally get the Brainseed to properly track the incoming pitch CV. Had some problems with the calibration, which apparently needs a factory trim so had to send it to US from EU. It is a great addition to a compact travel case, freeing up the main sequencer for other duties.
Anechoic
Post by Anechoic » Tue Sep 06, 2016 2:22 am
Added new video!
ratskull
Post by ratskull » Tue Sep 06, 2016 8:40 am
Seeding has a Depeche Mode vibe to it. I was expecting Dave Gahan to join in at any moment. :yay: Very nice!
Anechoic
Post by Anechoic » Wed Sep 07, 2016 6:33 pm
Thank you ratskull - I am such a big DM fan, its nice to believe their style has somewhat permeated to me from over-listening to them!
p@@@nts
Post by p@@@nts » Fri Sep 09, 2016 6:54 pm
Man, I too am really digging these! Thanks for posting!
Can you talk a little more on how you're getting these long evolving note sequences? What is sequencing what, and triggered by what?
So mesmerizing…
p@@@nts
Post by p@@@nts » Fri Sep 09, 2016 7:06 pm
D'oh, I now see the the additional info on vimeo. So STO is the bass voice - what is sending it it's slow v/oct sequence? Hope you don't mind the questions...
robvec
Post by robvec » Sat Sep 10, 2016 3:22 am
Really enjoyed those thanks for sharing!
Anechoic
Post by Anechoic » Sun Sep 11, 2016 1:34 pm
Thanks for your comments - very much appreciated 8-)
p@@@nts wrote:D'oh, I now see the the additional info on vimeo. So STO is the bass voice - what is sending it it's slow v/oct sequence? Hope you don't mind the questions...
Yes there are patch notes on the Vimeo and SoundCloud pages, but to answer p@@@nts the long evolving note sequences come from the STO that is sequenced by the Brainseed. The v/oct is patched through Kinks Sample and Hold so as to change note in time, but slower than, the main sequence.
detailed patch notes below:
PATCH NOTES FOR FERFIN TRACK
Three voices from MakeNoise STO VCO, Noise engineering Sinc Iter VCO, Mutable Instruments Rings, all triggered independently by Abstract Data Octocontroller and mixed with MN Optomix and Synthrotek Stereo Output Mixer. Effects via MI Clouds in Spectral Madness mode (+Reverb), Disting in Delay mode, and 4ms Dual Looping Delay.
Sequence programmed in Qu-Bit Octone and recorded into AntiMatter Brain Seed. Sequence G D G manually scaled up and down on downbeat G in m pent scale.
SINC ITER
sequenced on every step by Brainseed
Super mode
ALM Pip Slope envelope into Optomix Ch 2
BI out ~ WMD SSF Multi Mode Filter
MMF ~ Disting Delay
Disting ~ Optomix Ch 2
Optomix Out 2 ~ Output Mixer Ch 4 (R)
STO
Sequenced every 3 steps on downbeat by Brainseed through MI Kinks Sample and Hold
All three waves used
Variable wave ~ Malekko Mix 4 Ch 1
Sine wave ~ Output Mixer Ch 1 (L)
Sub wave ~ Optomix Ch 1
Optomix Out 1 ~ WMD SSF DPLR
DPLR Out A and B ~ Malekko Mix 4 ch 2-3
Malekko Mix 4 ~ Output Mixer Ch 3 (L)
Strike input of Optomix Ch 1 triggered by Octocontroller Loop channel
Control input of Optomix modulated by Qu-Bit EON envelope in sync with Sample and Hold
RINGS
Sympathetic Strings in 2 note polyphony (both orange leds)
Sequenced by Brainseed, Strum from Octocontroller Loop channel
Both Odd-Even outputs multed to both the 4ms DLD A-B Inputs and to Clouds L-R Inputs
Rings O-E Out ~ DLD A-B In
Rings O-E Out ~ Clouds L-R In
DUAL LOOPING DELAY
DLD A Out ~ Output Mixer Ch 1 (L)
DLD B Out ~ Output Mixer Ch 2 (R)
CLOUDS
In Spectral Madness Mode
Clouds L Out ~ Output Mixer Ch 1 (L)
Clouds R Out ~ Output Mixer Ch 2 (R)
PEAKS
Drum mode
BD triggered by Octocontroller Loop channel
HH triggered by Batumi Ch 1 square wave
BD - HH Out ~ WMD SSF SPO In 2A and 2B
SPO Out 2 ~ Output Mixer Ch 1 (L)
BATUMI
Ch 1 Sync from Octocontroller Gates channel
Ch 2 Verhulst ~ STO Shape
Ch 3 Verhulst ~ Rings Damping
Ch 3 Sine ~ Rings Brightness
Ch 3 Square ~ SPO Ch 1A ~ Optomix Ch 1 Damp
Ch 4 Sine ~ Rings Position
RADIO MUSIC
Loop triggered by Octocontroller Gate channel
Out ~ Malekko Mix 4 Ch 4
gis_sweden
Post by gis_sweden » Mon Sep 12, 2016 2:07 am
As said lovely :yay:
All of the tracks!
polyoptics
Post by polyoptics » Tue Sep 13, 2016 12:59 pm
Very nice tracks -- I especially like the small setup, there is a quite a nice result from this little system and a you control over it! Great stuff!! :yay:
Anechoic
Post by Anechoic » Tue Sep 13, 2016 8:31 pm
polyoptics wrote:Very nice tracks -- I especially like the small setup
Thanks! Yes, I find the constraints from the small travel case make me dig much deeper into each module, and their interactions with each other as a system.
Just added a new video!
Metalcat73
Post by Metalcat73 » Fri Sep 16, 2016 2:15 pm
Wow, I'm putting my first system together in a case about that size, and I was really hoping I could accomplish great music similar to this with it...and you've proved that to me so thank you! Great stuff
Anechoic
Post by Anechoic » Sat Sep 17, 2016 7:40 am
Metalcat73 wrote:Wow, I'm putting my first system together in a case about that size, and I was really hoping I could accomplish great music similar to this with it...
Thanks - and good luck with your system! It took a fair amount of module-swapping between my main rack and this travel case in order to find the best combination of modules that fits, and also provides enough flexibility/variation/number of voices. The difficult bit is deciding which modules to keep out. And the process never really ends...
Anechoic
Post by Anechoic » Sun Nov 13, 2016 9:29 am
Added new video exploring the Zvex LoFi Junky module processing MI Rings.
deltaAquarii
Post by deltaAquarii » Wed Nov 16, 2016 2:14 pm
great videos man - i like seeding & agral the most!
technomania
Post by technomania » Thu Nov 17, 2016 9:06 pm
Cool videos :bananaguitar:
franman69
Post by franman69 » Thu Dec 01, 2016 10:19 pm
nice tracks.. I enjoyed them!
koyl
Post by koyl » Fri Dec 02, 2016 6:19 am
Those are great !
and happy to see we have a lot of modules in common (and in the same case !).
Any chance that you end up releasing them as an album or make them available for download ?
declutter
Post by declutter » Fri Dec 02, 2016 4:38 pm
These are great. Thank you.
Anechoic
Post by Anechoic » Mon Jan 01, 2018 2:52 am
New videos regularly added and link to Soundcloud repository
spacetime
Post by spacetime » Mon Jan 01, 2018 6:48 am
Thanks for the music!
Anechoic
Post by Anechoic » Mon Jan 01, 2018 7:13 am
thank you for giving it a listen!
Anechoic
Post by Anechoic » Fri Jan 05, 2018 12:20 pm
Added new video.
Return to “Your Tunes Here”
