How much resistor change affects LED?
Moderators: Kent, infradead, Synthbuilder
terjewinther
Post by terjewinther » Sat Aug 20, 2016 10:07 am
If I think the LEDs in one module is somewhat too bright, can I just change the resistor driving the LED without any problems?
The module in question is the Little-LFO, originally with a 1k8 resistor. I did not use the standard LED for this module, and even though I have changed the resistor up to 3k8, it is still too bright for me. May I just continue to increase the resistor until it suits me? What happens if I put in a 100k resistor?
The module is working perfectly in all other aspects.
Synthbuilder
Re: How much resistor change affects LED?
Post by Synthbuilder » Mon Aug 22, 2016 3:18 am
terjewinther wrote:May I just continue to increase the resistor until it suits me?
Yes.
A lot of the newer LEDs can be much brighter than the older types. This especially applies to the blue and white ones you get these days. So just try a range of different values until you get a the desired effect.
100K is probably too high but I think I've used 33K on some blue ones.
Tony
terjewinther
Post by terjewinther » Mon Aug 22, 2016 11:07 am
I ended up with a 10k resistor. Used the old trick of putting in a trimmer, and adjusting until it was more or less like the LEDs in the other modules. Then desoldered the trimmer and tested, and it was close to 10k, so that worked for me.
