A different Forum Challenge
Goto page Previous  1, 2, 3, 4, 5  Next [all]
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Music Tech DIY
Author A different Forum Challenge
plord
Wacky for Wiard Wiggler
Last Visit: 24 May 2013
PostPosted: Sun Oct 19, 2008 6:45 pm    Post subject: Reply with quote Add User to Ignore List
consumed wrote:
gonna have your klee running by next weekend?
It'll be a miracle but I'm gonna try. I'll get up some close ups of the other panels a little later.
Kwote
Voltage Controlled Crackpot
Last Visit: 14 May 2011
PostPosted: Tue Oct 21, 2008 2:49 am    Post subject: Reply with quote Add User to Ignore List
i believe in miracles!
Link
kwotemusic.com
my other sites
Luka
Last Visit: 25 May 2013
PostPosted: Thu Oct 30, 2008 7:20 am    Post subject: Reply with quote Add User to Ignore List
ok, finished xoxbox, waiting for IO panel and sold some more bits
bench
xoxbox < waiting for Io mod kit
wave multiplier < seems to have cut out grr
cgs synthacon vcf < needs caps
tube filter boxes < need panel and then laquer box
read for panels
4 x qfgs <just needs some lf444/tl064s but pretty close
dual TH-vca1
dual wogglebug one populated
pcbs to build now
quad lfo < next
digisound I/O < next
mb808 < next
cgs vco
yusynth ems vcf
4x lpgs
analog computer
mankato
matrix mixer
neural agonizer
tau phaser
box'o'trix
doomsday machine
^ arranged in order of build smile
and for other peeps
krautrock phaser box < working on now
melbourne australia
soundcloud
lastfm
vimeo
wtb:
220/230/240v Broken Dp4
20x20 ghielmetti matrix
taking offers on (melbourne pickup)
revox pr99 mk2
allenheath zed420
plord
PostPosted: Mon Nov 10, 2008 1:20 pm    Post subject: Reply with quote Add User to Ignore List
Klee construction makes you into a monk. Chop wood, carry water, build a wiring harness. Chop wood, carry water, build a wiring harness. and so forth.
Ok then, all wiring harnesses completed as of 3am this morning smile There's a task I never want to do again. But I checked every one from the bare wiring end to a test pin header and we're good to go. Tonight, sleep, then the actual work of soldering it all together can begin.
A note to anyone pondering Kleeness: it is blatantly obvious that building the headers is the only way to go. But you will cut, strip, tin, clamp, insert, and test about 200 wires during this exercise eek! It took me probably 12 hours total over 3 nights (but I am slow, and anal, and tested everything). If you got the parts kit from E-M, you will find you have about 16 "spare" um, those little wire doohickeys that you clamp to the tinned end and jam into the header. Thank god. I mangled 9 of them d'oh!
I have a little wiring station, with spools horizontally on a dowel poked through some scrap wood. It helped a LOT. I could pull 6 wires at a time and cut to the same length. After making one harness completely, I went with a suggestion in the Build doc, and cut all the remaining wires (as long as the farthest possible reach from my PCBs to a panel component), then stripped them all, then tinned them all, then went back to one-by-one assembly. That let me get into multiple little grooves where muscle memory and the lack of context switching made everything seem to go a little faster, YMMV.
Also, I will now lay claim to the most ghetto PCB mounting strategy ever. Pics to follow smile
In other bench news, I got my orders from Bridechamber, Mouser, and Allied, so I now *should* have all the parts in house to finish up the Attenuverter, Tau, Yusynth Diode filter, and the Buchla 281 ARs (oops, no, waiting on 10K lin pots from Futurelec for that...but close!). But for now focus is still on the Klee.
Luka
PostPosted: Mon Nov 10, 2008 4:15 pm    Post subject: Reply with quote Add User to Ignore List
those wires were such a bitch
melbourne australia
soundcloud
lastfm
vimeo
wtb:
revox pr99 mk2
allenheath zed420
neandrewthal
full clout y'all
Location: Spending warm summer days indoors writing frightening verse to a buck-toothed girl in Luxembourg
PostPosted: Wed Nov 12, 2008 2:30 am    Post subject: Reply with quote Add User to Ignore List
An update for this month. Hopefully next one I'll be done, but the VCO and BiNtic are killing me very frustrating
Fix it:
Wogglebug(damn bag of backwards BC550s from futurlec)
2x Buchla VC portamento (didn't know how to install the vactrols without a silkscreened PCB d'oh!)
CGS VCO (stumped confused )
2x buchla 281 (I don't know how the hell I managed to put 18V zeners in there instead of 10)
CGS Analogic(the last time I try trimming the leads before soldering)
Fonik PS3100 resonators(BC550s again)
2x tube vca (needed a "for dummies" bias switch wiring guide)
CGS BiNtiC(stumped confused )
Build it:
x0xb0x (All tuned up. Just gotta screw it in the case and add some 1/4" jacks for CV/Gate)
mankato filter
PS3100 resonators
fritz 5 pulser
tellun neural agonizer (PCB's and panel are ready, just waitin on them tanks)
tellun switching comparator (need a 3PDT)
CGS(from here on) BiNtiC
2x tube vca
3x dc mixer
15x LED driver
cascade mixer
digital noise
analog shift register (need a parts kit)
pulse dividers/boolean logic
xor/xnor
utility LFO (this one is aborted. Ran out of materials to make panels and won't be getting more for a while)
It was only a hundred miles or so to the ice caverns, and the second day, when we were lying out under the blistering sun-thing he had materialized, he sent down some manna. Tasted like boiled boar urine. We ate it.
Norman_Phay
tehpwnzriated
Last Visit: 23 May 2013
PostPosted: Thu Nov 13, 2008 11:15 am    Post subject: Reply with quote Add User to Ignore List
My DIY backlog is off the map :(
2 x JH tau phasers
5 (!) x JH kraut rock phasers
3 x JH triple ensemble - one of these works, the other 2 need some troubleshooting
2 x JH freq shifters
2 x JH scanner/vib. Or was it three. I can't actually remember
2 x Fonik dual mix/invert
2 x Fonik triple resonators
Oakley octal resonator
Oakley noise generator
4 x Topp 281 clone
4 x DJ Thomas' LPG clone
2 x ryktnk sequencers
Klee sequencer
JLH octave selector
JLH interval selector
Tellun corp add-on for MOTM VCLFO
Tellun corp add-on for MOTM ADSR
Tellun corp MUUB board (built up, ready to use w/MOTM480 filter)
CGS analog shift register
Now, about 1/3 of this stuff actually has the full set of components soldered into place, I just need to get the panels and get it wired up, ect.
I got this:
http://www.flickr.com/photos/16804034@N00/2999867969/
The packaging might be a bit OTT, do you think?
http://www.flickr.com/photos/16804034@N00/2999867975/in/set-7215760001 7769090/
It is a Wiard-ish format panel which will contain an Oakley "Equinoxe" phaser (which I already built and ATM have behind a MOTM-format panel) and the Oakley Octal resonator, so that'll be the first one. I plan on buying a panel a month.
Kwote
PostPosted: Thu Nov 13, 2008 12:24 pm    Post subject: Reply with quote Add User to Ignore List
LOL. that box was so big they might as well have thrown in a deep dish pizza. Guinness ftw!
kwotemusic.com
my other sites
Roycie Roller
Death Row Wiggler
Last Visit: 25 Apr 2013
PostPosted: Thu Nov 13, 2008 4:54 pm    Post subject: Reply with quote Add User to Ignore List
Peter Grenader Smacked in the head with a trout Driving ambulance Tombstone
Luka
PostPosted: Thu Nov 13, 2008 6:09 pm    Post subject: Reply with quote Add User to Ignore List
talk about inflation hehe
nice norman!
jesus 5 krautrock phasers
melbourne australia
soundcloud
lastfm
vimeo
wtb:
revox pr99 mk2
allenheath zed420
neandrewthal
full clout y'all
PostPosted: Thu Nov 13, 2008 10:24 pm    Post subject: Reply with quote Add User to Ignore List
Yeah, what are you gonna do with all those? That's more than $600 in JH PCB's you've got there eek!
I just put in my order for 1 tau, 1 kraut and 1 interpolating scanner 8)
Norman_Phay
tehpwnzriated
PostPosted: Thu Nov 13, 2008 10:45 pm    Post subject: Reply with quote Add User to Ignore List
The extra KR phasers and triple choruses I'm building for other ppl smile I'm Just keeping one of each.
Luka
PostPosted: Fri Nov 14, 2008 3:44 am    Post subject: Reply with quote Add User to Ignore List
so andrew what is wrong with your vco?
i can help you if you want
took me awhile to get mine rocking, but now it is fully functional
does anyone have a cgs synthacon vcf?
i extremely stumped with mine confused
need some help
just some pictures of a working finished one would do
im perplexed with mine
and how have you done your bias switch?
we can probably work through that too
melbourne australia
soundcloud
lastfm
vimeo
wtb:
revox pr99 mk2
allenheath zed420
Roycie Roller
Death Row Wiggler
PostPosted: Fri Nov 14, 2008 4:56 am    Post subject: Reply with quote Add User to Ignore List
Have you got the Elby version? Or Ken's? I think they both require some kludging to get operational, and the removal of some diodes to tame the resonance. I've got some photos of the kludges (done on the Elby pcb) if you'd like me to email them to you. I think the two pcb's are fairly similar in layout.
Luka
PostPosted: Fri Nov 14, 2008 5:22 am    Post subject: Reply with quote Add User to Ignore List
yeah the elby version, well it is a ken stone board
i bought this years ago and it didnt work so i just chucked it
trying to get it to work now
if you could email images and short description to me it would be awesome
coolhandluka-@-gmail-.-com
thanks roycie
melbourne australia
soundcloud
lastfm
vimeo
wtb:
revox pr99 mk2
allenheath zed420
neandrewthal
full clout y'all
PostPosted: Sat Nov 15, 2008 4:13 am    Post subject: Reply with quote Add User to Ignore List
You already did on page 2 Mr. Green but I haven't gotten around to checking it over yet. Well, I did, but discovered that none of the outputs worked this time. The core is still oscillating, so I must have blown up the TL072 or something last time I checked it. I'll have to fix that before I am back to where I was before, but I probably won't be able to look at it again until monday. I wish I could help with the synthacon, but I don't know the first thing about it confused
First I tried wiring it the way it is shown on the bridechamber page, but I must have done it wrong because nothing worked. Then I redid using the diagram guitarfool posted on e-music (the one I call the "for dummies" wiring guide) and it works great! It's really simple when you think about it. Just switching between the 2 different jumper/resistor combinations.
Luka
PostPosted: Sat Nov 15, 2008 5:56 am    Post subject: Reply with quote Add User to Ignore List
yup great, well i have a colour coded pcb diagram explaining all the sections for the cgs vco if you want
melbourne australia
soundcloud
lastfm
vimeo
wtb:
revox pr99 mk2
allenheath zed420
Kwote
PostPosted: Sun Nov 16, 2008 2:19 am    Post subject: Reply with quote Add User to Ignore List
i'd like that sir. i plan on building 3 of em in the future.
kwotemusic.com
my other sites
neandrewthal
full clout y'all
PostPosted: Sun Nov 16, 2008 2:32 am    Post subject: Reply with quote Add User to Ignore List
Kwote wrote:
i'd like that sir.
As would I smile
Luka
PostPosted: Sun Nov 16, 2008 2:34 am    Post subject: Reply with quote Add User to Ignore List
ok no prob, im just finishing making a ghetto-veroboard steiner vcf, once im done that ill check it out and make sure it all makes sense and post her up
debugging my vco taught me a lot about vcos and wave shaping it was a valuable experience
melbourne australia
soundcloud
lastfm
vimeo
wtb:
revox pr99 mk2
allenheath zed420
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Music Tech DIY All times are GMT - 5 Hours
Page 3 of 5
