Small MOTM style knobs / UEG
Author Small MOTM style knobs / UEG
bf
I seem to be weak in the force of the search.
Does anyone have the PN for the small MOTM style knobs like the ones used on the UEG?
I think this is the data sheet for the Tycos, but I'm not sure which size they are.
Thanks.
Moog$FooL$
tried smallbear??
bf
Smallbear has 1" 'and 3/4", both of which are cheaper than mouser if they are the right size.
consumed
the motm knob part is PKES90B1/4 which indicates a .9" diameter at the top (about 1" at skirt).
you are probably looking for the PKES60B1/4 which is close to .6" diameter at the top.
http://www.tycoelectronics.com/commerce/DocumentDelivery/DDEController  ?Action=showdoc&DocId=Customer+Drawing%7F4-1437624-6%7FA%7Fpdf%7FEngl ish%7FENG_CD_4-1437624-6_A.pdf
megaohm
They look like 45KN018-GRX from Mouser.
synthetic
I've used Mouser part# 506-PKES60B1/4, Alco PKES60B1/4.
pugix
I just got 25 more of those 506-PKES60B1/4 knobs. I'm doing a lot of 1U panels with them on a 1-inch grid, like this:
http://pugix.com/synth/mattson-vc-mixer/
Next up are two Mattson EG/VCA modules and a dual FOH Plague Bearers.
Those 25 knobs cost $41.50, less than 25 Switchcraft 112AX jacks at $42.75!
But some of the Alpha pots are on back order until mid to late June. cry
And for small 1/8" shafts if you need them:
http://www.surplussales.com/ShaftHardware/Knobs-13.html
bf
Thank you everyone.
