laser projection mapping
Author laser projection mapping
Ddorward
anybody have information on how to get started with this? there seems to be very little info out there that i can find........
memes_33
you might have more luck if you remove the "laser" aspect in your searches. projector mapping is the same with dlp, led, lcd, and laser- the technology behind the light engine doesn't affect the graphic aspect of blending/warping/mapping.
i am an AV designer, so i've designed the physical aspects of mapping/warping/blending many times in the past, but don't have any experience with the graphical or software sides.
zilzilzilzil
Check out madmapper
http://www.madmapper.com
VDU
Check out VPT if you're looking for a free option. Also it is built in max, so if you want to start pulling it apart and seeing how it's made you can thumbs up
https://hcgilje.wordpress.com/vpt/
