Best of CGS Build Thread
Goto page Previous  1, 2, 3 ... 21, 22, 23 ... 34, 35, 36  Next [all]
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Music Tech DIY
Author Best of CGS Build Thread
magman
Last Visit: 25 May 2013
PostPosted: Tue May 29, 2012 10:57 am    Post subject: Reply with quote Add User to Ignore List
The confusing mist slowly drifts away.
OK, it looks like I called them NKK switches in my original post, but from the Mouser part numbers they are actually C&K switches, as we have recently discussed.
It also looks like the Mouser part number for the Dress Nut has also changed (the original part numbers came of my Mouser invoice). The correct part number for the Dress Nut is 611-702501201.
Time to light a fire of clarity and apology to keep the confusing mists at bay.
Also time to go and edit a few earlier confusing posts.
Magman
Kopter
Funk Release Valve
PostPosted: Tue May 29, 2012 11:47 am    Post subject: Reply with quote Add User to Ignore List
Oh, don't worry, I'm just happy about the quick answer. Thanks for clearing things up!
0101010001101000011010010111001100100000011010010111001100100000011000 01011011100110000101101100011011110110011100101110
eagleroad
Last Visit: 12 May 2013
PostPosted: Tue May 29, 2012 7:26 pm    Post subject: Reply with quote Add User to Ignore List
I'm a little bit confused about the wiring of the dual mixer / dual VCA.
I understand that both CGS64 boards are used for the wiring of each dual module but I can only see one output on each board, in the mixer section.
Where should I wire the IN and OUT jacks for the Dual VCA?
Any help would be greatly appreciated!
djs
Last Visit: 24 May 2013
PostPosted: Tue May 29, 2012 8:05 pm    Post subject: Reply with quote Add User to Ignore List
It's because you need 2 pcbs!
"Noise is what the Earth is made of" - David Bowie
eagleroad
PostPosted: Tue May 29, 2012 9:48 pm    Post subject: Reply with quote Add User to Ignore List
two pcbs for each dual module? so four CGS64's in total? i thought that each PCB did double duty. d'oh!
djs
PostPosted: Tue May 29, 2012 9:59 pm    Post subject: Reply with quote Add User to Ignore List
Which panel are you making? I thought the dual mixer would be done by 2 cgs04 boards.
Ken stone lists the pcbs required here:
http://cgs.synth.net/pcb/bestofcgs.html
fluxmonkey
PostPosted: Tue May 29, 2012 10:01 pm    Post subject: Reply with quote Add User to Ignore List
check ken's Best Of page (http://www.cgs.synth.net/pcb/bestofcgs.html), all will be revealed...
www.fluxmonkey.com
please email (rather than PM) with any direct correspondence
eagleroad
PostPosted: Tue May 29, 2012 10:50 pm    Post subject: Reply with quote Add User to Ignore List
i'm currently wiring the voice panel B (#3 pictured at the top of the thread). It's not listed on the linked page. The pcb's were ordered quite a while ago and I thought ken sent me all I needed (which he may have). I've been searching through the threads for a while now but haven't found anything conclusive.
I have two CGS64 and thought that it was a split VCA/Mixer and that the dual mixer used one half of each pcb and the dual VCA used the other.
otherunicorn
Santa
PostPosted: Tue May 29, 2012 11:24 pm    Post subject: Reply with quote Add User to Ignore List
CGS64 is just a VCA. It has integral mixers, but they are part of the VCA, not for external use. The split down the center of the board is merely so those Euro guys can fold the thing so it fits behind their vertically challenged panels.
The dual mixer is the CGS81, and that IS two mixer circuits on one board.
You got that resistor in backwards...
eagleroad
PostPosted: Tue May 29, 2012 11:30 pm    Post subject: Reply with quote Add User to Ignore List
Ahh makes much more sense now. I'll be ordering more boards in the next month for the other panels and I'll get the mixer pcb then.
Thanks for clearing that up.
widgetoz
Last Visit: 18 May 2013
PostPosted: Wed Jun 20, 2012 5:21 am    Post subject: Reply with quote Add User to Ignore List
Luka wrote:
i wonder where i can get those hinged standoffs locally
none of my hardware stores stock 3mm stuff
ken do you have an aussie source for this kinda stuff?
I carry these in stock and are listed in the CGS section of my shop
mb123music
PostPosted: Sat Jul 21, 2012 2:12 pm    Post subject: Pulse divider and Boolean logic wiring diagram Reply with quote Add User to Ignore List
Hey everyone!
I'm looking for some info on wiring the Pulse divider and Boolean logic board on the best of cgs swamp panel. (wiring the pec to the panel components) Can't seem to find one on Ken stones Cgs site, seems to be for the other two boards though.
Any help would be awesome,
Matt. seriously, i just don't get it seriously, i just don't get it
JCM
PostPosted: Sat Jul 21, 2012 3:03 pm    Post subject: Re: Pulse divider and Boolean logic wiring diagram Reply with quote Add User to Ignore List
mb123music wrote:
Hey everyone!
That one is pretty straight forward. Just wire the appropriate jacks to the specific pads labeled on the board. You can ignore the ground connection since you are using banana's. LA and LC are for LED Anode and Cathode and can be ignored. You can also ignore the RSB pad because it looks like there is no RESET button on the panel. Looks like you need to wire up only one of the inverters.
http://tf50.tonefilth.org
JCM
PostPosted: Sat Jul 21, 2012 3:06 pm    Post subject: Reply with quote Add User to Ignore List
Looks like no reset included on the panel either, so ignore RST. Input jack to CLK.
mb123music
PostPosted: Sun Jul 22, 2012 12:09 am    Post subject: Reply with quote Add User to Ignore List
Thanks JCM Rockin' Banana!
C-Kay
Last Visit: 01 Aug 2012
PostPosted: Wed Aug 01, 2012 11:05 am    Post subject: Reply with quote Add User to Ignore List
Hello everybody
I just recieved my components in the mail and got a soldering iron! Time to get to work thumbs up
Thealien
Last Visit: 08 Aug 2012
PostPosted: Wed Aug 08, 2012 6:36 pm    Post subject: best of cgs b Reply with quote Add User to Ignore List
im almost finished with the best of cgs b. i have only 4 more things to wire up and was hoping someone could help me out. on the daul mixer where can i wire the aux in to? also on the wave multipliers bottom section, where do i wire the in and its corresponding pot? i looked at the sketch above and was unsure what the pci or dci was. this was my first build ever. got to say it was a blast and will be doing more and learning as i move forward into this beautiful world of crazzyness.
iopop
PostPosted: Thu Aug 09, 2012 1:28 am    Post subject: Reply with quote Add User to Ignore List
Nice build!
I had the same question about the AUX, http://www.muffwiggler.com/forum/viewtopic.php?p=506782#506782
Can't really help you right now about the Wave Multiplier, at work and it completely escape me how that was wired up.
diophantine
Last Visit: 14 May 2013
PostPosted: Sat Aug 18, 2012 9:43 pm    Post subject: Reply with quote Add User to Ignore List
I'm thinking of using blue LEDs on my BOG, MARSH, and SWAMP. (My MU system is mostly red & green + my Synthasystem is all yellow, so... variety!). Figuring out the RLED values on most things is fine, since the LEDs either have their own buffer, or share a buffer with a gate output in parallel. The CGS Programmer, however, has the LEDs in series with the outputs, so there's no obvious RLED... how would/should one modify the circuit?
otherunicorn
Santa
PostPosted: Sat Aug 18, 2012 10:36 pm    Post subject: Reply with quote Add User to Ignore List
On the solder side of the board, cut the track from the cathode of the LED. Link the 680R to the track that goes to the anode of the LED.
Add RLED between the cathode of the LED and the nearby 0V track.
Ken
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Music Tech DIY All times are GMT - 5 Hours
Page 22 of 36
