FINALLY! I believe I have gotten to the bottom of the invalid session and logout issues. Please continue to report your own experience in the appropriate threads in the "Forum Discussion and Requests" subforum. Thank you all for your patience and support! <3
Oscillatoscope2b
Author Oscillatoscope2b
MATSmile
::ABOUT
It can convert CV and audio signals into video and audio.
It works by changing the frequency of oscillators that are synced to a VGA sync generator.
The signal that is generated is output as audio on a mini jack connector, and as video on the VGA connector.
::CONNECTION
inputs:
- cv in for R,G,B pitch (starve)
- high gain audio in for R,G,B pitch (starve)
- cv in for sync horizontal
- cv in for sync vertical
- VGA out 640x480 60hz (actual resolution is that of the screen itself, because it is a analog signal)
- power in +)- 7.5v DC
outputs:
- audio out
- vertical sync out
- USB 5v out (only for use with VGA to HDMI converter shown in image on my website)
::CONTROLS
pots:
- R,G,B pitch (starve)
- R pitch
- G pitch
- B pitch
- sync horizontal
- sync vertical
switches:
- R horizontal/vertical
- G horizontal/vertical
- B horizontal/vertical
FetidEye
I've seen a demo with the prototype (+ played with it myself)
It is really awesome!
found a video:
johyde
Looks great!
- I don't really understand that part?
FetidEye
I think that the screen converts the input to its own native resolution
correct me if i'm wrong
glia
these are nice
tenshun
I just put together the kit the other day. A really easy kit with not that many components.
I need to get a adaptor to convert vga to composite in order to record into my video capture device.
The colors are bright and vivid when i connected it to my projector. It also makes a cool effects pedal too!
maggan
Cool! I've build some gieskes-stuff and they are all very well explained with pictures and stuff. Looking forward to order and build this as well. I think I will convert the vga too (composite I could do or component just for the capture card).
