Announcing ALM017 - Pamela's NEW Workout
MUFF WIGGLER Forum Index -> Eurorack Modules Goto page Previous  1, 2, 3 ... 52, 53, 54, 55, 56, 57  Next [all]
Author Announcing ALM017 - Pamela's NEW Workout
ALM
Bobbyr77 wrote:
Yes works as expected manually
Likely a bug in which case :( want to shoot us an email (help @ busy) and I'll investigate further..
cptnal
Bobbyr77 wrote:
I have checked through this (very long) thread and the user manual and cant seem to find any reference to a problem I have been having
I want to use PNW for rhythmic loops to trigger drum modules etc using rskip and loop, and use external CV to set the loop length. This works as expected, I can get a recurring 8 step loop. However I expected that when I set the loop length to 0 (send 0v to CV1 in) and then back up to 8 steps (using Maths Ch2 for example) that I would get a new loop, but I don't. Its the same if I use the stepped random - I end up with the same loop. Yes I can change the length of the loop but not get it to 'reseed' (correct terminology?) at 0.
Is this normal behaviour? user error? is there a way that I can get a new loop using external CV or will this only work if I manually set to 0 and then up again to 8 in the module?
Thanks in advance
I haven't tried this for a while, but I did get it to work...
First of all your gate length from Maths needs to be long enough (probably needs time to accumulate new values for the loop). Second, from your description it sounds like you're doing it upside down. It would need to tick along at 8 (looping) and dip down to 0 (reseed). So you'd have to be sending a negative voltage.
That's how it sounds to me anyway, and it has been a while... This is fun!
Bobbyr77
Excellent thanks for the quick response, I will be in touch
Thanks cptnal - I am doing it manually in Maths, turning ch2 knob down (even into -ve territory) then back up to get my new loop but not sure about -ve voltage - CV1 on PNW only accepts +ve anyway right? so should be at 0 steps (and therefore reseeding) when I got into -ve CV I will have another play with this anyway, try it upside down and contact ALM if I still have no joy
Warius
I have a question dear wigglers.
I send the random waveform, through a quantizer (Pico Quant) to the pitch of an oscillator to create loops of random notes.
The Pico Quant has a clock out, so with each change of voltage, I can trigger the vca/envelope-module where the oscillator goes into.
When I also assign a rhythm of euclidian steps or a percentage of random skipping to the looped random waveform, the PNW sends a voltage when a step is skipped (correct?). Therefor, via the quantizer, the vca is also triggered when there is no note, and the oscillator is heard. I don't want that.
Is there a way to not have the vca triggered when a step is skipped due to euclidian steps or the random skipping?
grep
I think the answer lies in how the Pico Quant clock out works. From the manual: "The output trigger will appear on each cv step change." So say Pam's output is at 2v and the next step skips, the output drops to 0v. This is a cv step change and the clock out triggers. I can't test this as I don't have a Pico Quant.
You could try triggering the vca by multing Pam's random output to the Quant cv in and to the vca in. Perhaps this will give you the desired result...
Jaypee
Is there a way PNW send 1 gate when I press play? and only when I press play?
I'd use it to trigger recording.
J.
JakoGreyshire
J.
If you set the gate on one channel to offset 100%, then when you press play the gate will remain high (on)... This is useful for synths that require a constant gate on signal to run a sequencer or other things....
That is the closest thing I can think of for your question...
Oh wait!!! I just tested it out and there is a way to do that!!! Just scroll past all the time multipliers and there is a setting that looks like a square gate and another one that looks like the falling side of a square gate... The gate one will fire a gate/trigger when pushing the start button and the falling edge one will fire a gate/trigger when stopping Pam...
Ta-dah!! thumbs up thumbs up
Jaypee
JakoGreyshire we're not worthy
Warius
That might be it @Grep.
I tried the multing. The random waveform doesn't trigger the vca every time the stepped output changes.
I'm a continue my research !
timeforest
im trying to wrap my head around PNW in conjunction with oC - could anyone tell me how to send random steps from pams into oC (thinking i want to use this for CV inputs in the ASR and quantermain apps)
boxxgrooved
Doing a search in Youtube for 'pamela's workout' produced results I wasn't expecting
namon
Searched my self, now in the best shape of my life.
srogers
Apologies if this has been addressed before, but is there a way to get PNW to NOT send a gate when starting the clock? I have two gates that I want out of phase by 50%, but they both fire when I press start which is not what I was expecting.
SnakesandBladders
I'm curious about something similar. I want a gate to fire at /128, but not at the very beginning when I start the clock. I know I could start with that output muted, then unmute it before /128 comes around, but if there is a workaround to this that I've missed I would love to know about it hmmm.....
JakoGreyshire
Not in front of my modular for a few days, but isn't there a delay setting?
SnakesandBladders
There is a delay setting. It will still have a gate trigger as soon as start is pushed. Basically what the delay setting is for is to delay a waveform cycle after it is triggered, which will cause the end of said waveform to be clipped off abruptly when the next trigger hits. You can choose which steps the delay setting will do this to with the divisor.
Fidi
You could set EStep to 32, ETrig to 31 and ERot to 01. This way the first Trigger doesnˋt play, the following 31 Triggers at /128 will fire off. Only every 32nd trigger will be skipped (takes a veeeery looong time at /128)...
Fidi
Double post...
SnakesandBladders
This is a neat idea. I'll give it a shot and see what is up.
Esgal
Anyone mount the PEXP-1 on the left of Pam? Will the cable reach?
jmeisse
Yup!
Esgal
jmeisse wrote:
Yup!
Excellent!
BTG
Running into a weird issue, I’m clocking pnw externally and also run. Occasionally when I start it will change the multiplier on one of the outputs from x2 to x4 or back. Any idea what that might be?
Crimesofthecrown
Finally got mine and am in absolute love.
grep
Sounds like the Run option is set to Rotate Outputs (RA or RR).
Page 53 of 57
