PS800, PSCONN3 mounting with RAK-2 Bare
Author PS800, PSCONN3 mounting with RAK-2 Bare
diophantine
Will be picking up a RAK-2 Bare combo shortly for the Frac system I've recently started. The plan is to put this in a 12"-deep wood rack from nice-racks.
How do you folks typically mount the PS800 and PSCONN3 in such a setup?
I imagine that you can screw the PS800 on one inner side (with switch and inlet facing out). But then would you mount the PSCONN3 also on an inner side of the rack (would require some 18" module power cables)? Or mount it in the middle of a 1U rear rack rail?
Or would you try to mount both the PS800 and PSCONN3 on a 3(?)U rear rack rail?
drumsofd00m
Whether separate or together, I'd put them on (a) rear rail(s), then leave empty spaces or ventilation grilles above and below. Makes for better emission of heat than mounting to a wooden side panel, and also better distribution of weight.
fracmonkey
The chassis version of the RAK2 is only 8" deep and has the psconn3 and ps800 mounted inside on the rear surface. If you could diy a box, you could save some money, size and weight. But 12" could come in handy for some larger effects, mixers, etc.
diophantine
Thanks guys!
Just ordered the combo, will test out a few options once I have it in hand.
It is going to be a tall rack (33U), otherwise I would have probably done a 8-10" deep one.
fracmonkey
Wow. You're in earthquake country. Be sure to safety wire the top to wall studs.
diophantine
fracmonkey wrote:
Wow.
That's what I said when I saw the FedEx quote for shipping it...
We're actually pretty safe here, surprisingly (knock on wood...) - no major faults through San Diego. But I still try* to keep stuff as earthquake-proof as possible/reasonable.
* = usual disclaimers apply.
