ADSR VCA and loop problems (solved)
Author ADSR VCA and loop problems (solved)
The ADSR out is working fine. Gets triggered and the shape looks correct. But the loop option doesn't work: The LED is either on or off (using the sustain knob). The output voltage stays at 5V, whatever the pot settings are. I can see the loop pulse at R22/pin 1, which changes with pot settings and the range switch. U4/pin 7 shows correct ADSR out in gate mode, but in loop mode: nothing!
After replacing U8, I can see little improvement: at U4 pin7 I can see the envelope in loop mode @140mV, whereas the envelope in gate mode is 380mV. Which is strange, as the input @ U8 pin1 has the same amplitude in gate and loop mode.
Also the VCA doesn't work, the output is always zero.I can follow the CV-IN voltage up to R31, but at the input of U7, the signal is lost. U5 pin 7 has the inverted ADSR output. I've replaced the LM37000, but the behavior is the same. Removing U7 shows the correct signal at Pin4/5. the values for R31 and R30 are correct (checked). Q5 is also working (checked).
Any idea, what to check next?
VCA does work now. My mistake, I accidently put a 3k3 resistor instead of 3M3 as R43. Now it works.
Same problem with R15: after replacing it with a 3M3 resistor, looping also works. I think, I have to check myresitor supplier or check each resistor before inserting it. Lesson learned hihi
