| View previous topic :: View next topic |
| Author |
w00t! Plague Bearer FSU module! |
wetterberg Super Deluxe Wiggler
  Posts: 6835 Location: Copenhagen, Denmark.
Posted: Wed Oct 01, 2008 8:56 pm Post subject: w00t! Plague Bearer FSU module! |
I've been eyeing the Flight Of Harmony Plague Bearer unit for a while, but now he has modularized it, ftw (click pics for website)
Fantastic pricing too, if you ask me, the dual (above) is 145usd. There's a single-unit version too, which is 75usd AND, the best part, if you ask me: BAREBONE versions are just 35(! sic!)usd! That's about the same as you'd normally pay for pcbs!
We exchanged a few emails reg. custom orders, and the response was instant and friendly. The barebones can be adjusted from 1vpp to 10vpp easily, and they take both Doepfer and Frac power (haven't seen that before!)
I'm PROMPTLY getting a set of these.
http://www.flightofharmony.com/pbBarebones.html
http://www.flightofharmony.com/pbModules.html
they're the pure nasty. Love it. But more importantly, he's one of those dudes that just seems to be doing the right things for the scene, if you know what I'm getting at - it's not a get-rich-quick scheme or overdesigned crap. I desperately want him to just keep doing modular stuff.
Andreas |
| Back to top |
parasitk I Play Loco Gigs
  Posts: 3912 Location: NY/PA
| Back to top |
Cybananna Funniest Guy
  Posts: 1379 Location: Ohio, USA
Posted: Wed Oct 01, 2008 10:37 pm Post subject: |
| I really want to like it, but the samples didn't make me crazy for one. Have you heard any other samples? So many times, equipment can do so much more than what's in the demos. I'd be interested to hear more. |
| Back to top |
GCF Common Wiggler
  Posts: 172 Location: Downers Grove, IL
Posted: Wed Oct 01, 2008 10:54 pm Post subject: |
What exactly does it do? A filter or something?
I remember looking at the page awhile ago, and either not understanding what it was doing or just not liking the samples. |
| Back to top |
eyehue High Desert
  Posts: 241 Location: flagstaff, arizona
| Back to top |
flts Veteran Wiggler
  Posts: 532 Location: Finland
Posted: Thu Oct 02, 2008 1:55 am Post subject: |
| I guess the "original" page has a better description, seems like a really cool beast. Kind of like a weird easily distorting filter and a noise gen in one. Some parts of some examples sound like badly behaving brother of vactrols, when the filter is "plucked" with a single pulse input. I could see this one working in other contexts than pure FSU too... |
| Back to top |
Posted: Thu Oct 02, 2008 8:30 am Post subject: |
yeah, the best read about this is in the section for the original Plague Bearer, which had four units in it:
| Quote: | It is designed to infect, corrupt and pervert a signal beyond recognition. It contains four Voltage-Controlled Resonant Bandpass filters that were designed with the goals of maximum signal alteration and maximum parameter controllability. Each filter has controls for varying the high and low corner frequencies of the passband, as well as variable gain and an input attenuator. Each section of the Plague Bearer can be used as a filter, an oscillator, a noise generator, or even as a resonance oscillator!
Depending on the settings, the filter can be a lowpass, highpass, single-bandpass, or multiple-bandpass. Adjusting the resonance point can cause the filter to self-oscillate in many ways: By adjusting the controls to just below the point of oscillation, and then applying a pulse, square, or other abrupt-edged input signal waveform will “ring” the filter. A simple “click” on the input can give a percussive output sound – from bass drum to bell to a harsh metallic clang; Crank the controls up and this beast will scream like a banshee! The oscillation can be damped or continuous. Chain a couple in series and get accumulating feedback – the build-up can be slow, fast or instantaneous. White Noise is easy to do - you don’t even need an input signal! Turn the input all the way down, and then slowly turn the gain up. You can adjust the “color” of the noise with the frequency controls. Daisy-chaining multiple filters can give a “comb” or multi-phase noise. About phase-shift characteristics: A single filter can give a STRONG chorus effect if so desired, useful as a sub-oscillator or just to “fatten” a sound
The Plague Bearer’s patchbay is designed to fit the most patch options possible in the small space available. Each filter has four Input/Output (I/O) connections: High CV, Low CV, Signal In, and Signal Out. Each of these has two jacks, one 3.5mm phone jack for external signals to avoid floating grounds, and one 0.080” tip jack for internal patching between filters. Each pair is direct-connected as a multiple – NOT a summing node! I have found this setup to be the most fun! |
| Back to top |
neandrewthal squelchy wobloid
Posted: Thu Oct 02, 2008 9:33 am Post subject: |
| Wow, that writeup makes me want 4, even though the sound samples did nothing for me. |
| Back to top |
Posted: Thu Oct 02, 2008 10:35 am Post subject: |
| same feelings I had. |
| Back to top |
| Back to top |
Posted: Thu Oct 02, 2008 11:07 am Post subject: |
| I'll wager that the samples aren't at all indicative of what these units can do in terms of modular synthesis. |
| Back to top |
| Back to top |
humanfaculties Learning to Wiggle
  Posts: 37 Location: Seattle
Posted: Thu Oct 02, 2008 2:25 pm Post subject: |
I have the original PB, with four seperate filters; definitely fucks shit up without mercy. It's not a pretty filter at all, but if you've heard the sound samples then that should come as no surprise I'd think. There's some really cool organic tones hidden amongst the skronk....though, always predicting where they'll be can take some patience.....lots of range with the controls. CV really makes the PB come alive.
Overall, it's a very weird filter that certainly has it's own peculiar sound. I can see how some people wouldn't care for how it distorts, but I've found some good uses for it. I fuckin love putting it before my polivoks vcf...ripping heaviness.
fwiw, Flight was a pleasure doing business with...attentive, and always great about updates. Good guy. 8) |
| Back to top |
Posted: Thu Oct 02, 2008 3:21 pm Post subject: |
@humanfaculties, very cool, thanks for chiming in!
Is there *any* chance that we could get you to rig a sample with a ton of cv control, perhaps as a part of a bigger modular synth setup?
I am looking to basically re-construct the PB in eurorack format, so 4 units behind one panel. I would love to hear the system in the context of modular synthesis.
cheers! |
| Back to top |
Posted: Thu Oct 02, 2008 4:16 pm Post subject: |
| wetterberg wrote: | | @humanfaculties, very cool, thanks for chiming in! |
Hey, you're welcome. 8)
| wetterberg wrote: | | Is there *any* chance that we could get you to rig a sample with a ton of cv control, perhaps as a part of a bigger modular synth setup? |
No promises, but maybe this weekend if time allows.
Just my opinion, but I've found that cascading the 4 filters at once is usually overkill when I patch up the PB.....there's points with the resonance/gain up where, from almost no perceivable effect, it can jump out way too aggressively to be useful....unless the goal is to destroy some speakers. For best results I almost always use a pair of filters. Much more control over the sound. |
| Back to top |
Posted: Thu Oct 02, 2008 6:10 pm Post subject: |
| that would really be killer, mate. |
| Back to top |
D/A A/D glorious dissonance
  Posts: 1745 Location: Halifax, NS, Canada
| Back to top |
REwire Super Deluxe Wiggler
  Posts: 1129 Location: Los Angeles
Posted: Fri Oct 03, 2008 6:46 pm Post subject: |
Where are these demo's you've all been talking about?
Also, if these demo's were of that 4 filter stand alone box, would a single 8hp version of this be lackluster? _________________ http://www.REwireMusic.com
NEW CD "Organism" Promo Video HERE |
| Back to top |
thetwlo Veteran Wiggler
  Posts: 552 Location: seattle
| Back to top |
Posted: Fri Oct 03, 2008 9:14 pm Post subject: |
http://www.flightofharmony.com/Plague_Bearer.html
I listened to the samples a lot and asked the guy a few questions. He was friendly and quick to answer. I decided to give it the benefit of the doubt and bought a single one.
It should be here in about 2 weeks. I'll post some samples of it when it arrives.
The thing with it is, the samples seem somewhat dull. but, there's not a lot going on with them. When I first started getting into modulars and didn't know what different modules did, I hated the demos that had several modules interacting because I couldn't understand what was doing what. They sounded cool, but they didn't tell me anything about the module I was interested in. I wanted just a basic sample, nothing fancy. That seems to be what these are, simple samples. I hope that put in the context of a modular system , it comes alive a bit.
If it doesn't, I'm not out that much money, and i've supported a nice guy trying to do his thing. No harm there.
not sure how much having only one will impact the sound. |
| Back to top |
