Integer Divider Software Update
Discussion and support for STG Soundlabs modules of all formats.
Moderators: Kent, infradead, suitandtieguy
dhergott1
Post by dhergott1 » Mon Apr 10, 2017 9:31 am
I heard there might be an update for the Integer Divider to help with higher audio rates and the occasional freezing issue - any word?
suitandtieguy
Hammond King
Post by suitandtieguy » Wed Apr 12, 2017 3:00 am
after the EG is done! :bang:
http://suitandtieguy.com
http://stgsoundlabs.com
suboptimal wrote:... if it's music you want to make with your modular, STG should be in your system.
dhergott1
Post by dhergott1 » Wed Apr 12, 2017 9:39 am
:tu:
sbuge
Post by sbuge » Tue Oct 24, 2017 4:09 pm
Is this normal behaviour?
Everything works fine with my Divider exept - when using /3 output I have to use a little bit of offset or amplification to fire my envelope generators or shift my sequencers etc. This is weird because every other output works fine (and without need of offsets) :hmm:
This is not a big deal for me
(because after adding offset it divides/operates fine),
but I am just wondering...
And when I use divider to audio rate applications this is not a problem at all
--> I get the correct interval and it has enough volume.
x_x_x_x_x_x_x_x_x_x_x_x_x
paitapes.bandcamp.com
Return to “STG Soundlabs”
