FOLDER PCB/Panel set available [Korb-Modular]
Author FOLDER PCB/Panel set available [Korb-Modular]
koerby
Hi
Finally FOLDER PCB/Panel set is now available:
What is FOLDER?
- Analog Dual Wave-Folded VCO
- Two independent VCOs
- Pure Analog Signal Path
- 2x4 switchable Waveforms (Ramp/Tri/Square/Sine)
- Adjustable PWM
- VCOs Single Out
- VCOs Mixed Out
- Mixed Wavefolder Out
- VCO Sync (OSC1<=>OSC2)
- Expander Port
How does it Sound?
Shop: https://www.korb-modular.com/shop/
Build Docs & BOM : https://github.com/Korb-Modular/02_FOLDER/tree/master/05_Docs
If you have further question please drop me a line: info@korb-modular.com
GryphonP3
Wow!! Very impressive for the price and simplicity!! You guys need to keep em coming, your stuff has really been a breath of fresh air. Your interpretation of the classic modules has even been very new and exciting.
Zaibach
Looks great! Can you tell us what the expander port will be used for?
koerby
direct access to all four waveforms of each VCO simultaneously, CV-control for the PWMs, Lin-Control for each VCO
Maybe i'll add also a trigger-in for switching the waveforms on the main Modul
sammy123
yan6
Out of stock already cry will there be another run of them
tobb
awesome!
tommy.york
this looks so clean. we're not worthy
will watch your store for projects. almost certainly will pick up some VCA's, if not another one of these when they're re-released. :]
StringEmil
Wow!
Any chance of these being released as built modules?
I have never soldered in my life!
Yes, I need to learn, but there are multiple reasons I am staying away from DIY!
LektroiD
I just went to buy one. Sold out already! When will these be back in stock?
koerby
I hope end of next week FOLDER will be back in stock
Drop me a short line and i'll inform you: info@korb-modular.com
LektroiD
Already sent an email about 12 hrs ago. Did you get it?
koerby
deleted
koerby
a small number of folder sets is back in stock
atte
I have a few questions:
1) I got an essential kit with SMD pre-soldered + the two included tempcos and knobs included. So this means I only need trimmers, LEDS, pots, jacks, power and optionally expander, right?
2) I'd like to source from Tayda and/or thonk, looking at the knobs, it seems the 7 small pots should be D-shaft, what about the large one? Will thonks D-shaft pots work: https://www.thonk.co.uk/shop/alpha-9mm-pots-dshaft/? Linear or audio?
3) Looking at the PCB it looks llike thonkiconm jacks, correct?
4) I think the font on the panel is a bit small, so I would like to try my hands on a one-off panel re-design. Is there a service somewhere that will make me a single panel without breaking the bank?
5) The build manual stops and measures between steps. Since all SMD are already done, wouldn't it be best just to go ahead and solder up the thru-hole, measure it and connect to power?
koerby
+ SPDT Switch
+Momentary Switch (+Caps)
All of them are D-Shaft and linear and yes the ones from Thonk will work.
Yes
Frontpanel Express is ok, they offer also a digital print.
The price is a little bit high, but for a single pices still ok
Yes, but for the first test i would only snap the pots in.
If everything is fine, you can solder them
atte
What's the correct orientation of the leds? Long or short leg towards edge of board?
EDIT:
Looking at this + diagram it seems it's short leg towards edge of board, right?
https://einhugur.com/blog/index.php/basic-electronics/led-orientation/
KT
did anyone made an expander pcb/panel? I can't find much info on this.
