ETI/Maplin Transient Generator
MUFF WIGGLER Forum Index -> Music Tech DIY Goto page Previous  1, 2 [all]
Author ETI/Maplin Transient Generator
4floorsofwhores
I'd love a full set cheers
fitzgreyve
whoop_john wrote:
fitzgreyve wrote:
THe lfo has a chebyshev filter, this one is bessel.
(I am quoting electric druids datasheets).
If anyone wants to try and see if there is any difference in practice:
for bessel, R2=12k, R4=12k
for chebyshev R2=33k, R4=47k
Your PDF for the Transient currently states R4=33k, not R4=12k as you say above.
Sorry, my typo in the posting - for Bessel R2=12K, R4=33K
**I will be placing an order for panels on Friday 19th. If anyone else is interested, let me know before then. **
Ayab
Hi whoop_john
Yes, I was getting over excited by the unusual naming of the panel controls. Being impetuous is just one of my bad habits! But I do also like the idea of arpeggios - thanks for clarifying. I'd be up for the Maplin VCA too.
How different VCA's sound depending on design and choice of components is certainly interesting - and how they overdrive.
Fitzgreye
I made a paypal payment for a set but it has just been refunded. Whats the deal? *EDIT* Sorry, just seen the note with the paypal refund stating that you are waiting until panels arrive before taking orders. That's two cases of my assumption problem in one thread!!
Have a good weekend folks.
fitzgreyve
I'm ordering panels and PCBs based on the responses above.
I'll let you all know as soon as I have these in stock.
ArboriaAuralist
w00t
KSS
whoop_john wrote:
The ETI VCA uses an MC1496 and there are various VCAs and ring modulators around that are based on this IC. As far as I know the ETI version is the only one that does both jobs in one.
PAIA 4710
fitzgreyve
Panels are now in and looking good.
I've now mailed everyone who expressed an interest so far.
Reminder that I also have limited "BETA" PCBs available which need one link wire adding (see build doc) - if you are happy with one of these, I'll reduce the price by GBP 3. Let me know if you want one of these when you order/pay - First come, first served on these.
ArboriaAuralist
Panel & PCB have arrived and look great! applause
Swyndger
Hello!
I discovered this just now, and I hope, it's not to late.
Would be very interested in PCB, Panel and PIC. I would take a BETA PCB if the others are sold out smile
fitzgreyve
Swyndger wrote:
Hello!
PM'ed
latigid on
Mine came in the post yesterday. Many thanks!
fitzgreyve
post here (or PM) if any problems or questions.
woodster
What's the score with LED orientation, just wondering which is anode on the pcb ?
Larrea
Mine arrived two days ago; looks good.
fitzgreyve
the anodes are all toward the top of the PCB if it was installed in the rack (i.e. the left side of the PCB picture in the build doc).
woodster
Ahh, this thing is really amazing, some of the most wonky shapes and such dynamic interplay between the controls. Then I added some simple LFO shapes into the 2 CV's and all hell truly broke loose, it was a good moment.
This is fun!
whoop_john
I am confused by something in the manual where it states:
- TIME CV …if a jack is inserted in TIME CV, the Time control acts as an attenuator.
Surely the above relates to the LEVEL CV, not the TIME CV, or am I missing something?
fitzgreyve
This is fun!
For even more weirdness, possibly try feeding back the module output into one of the CV inputs (this is something I found on my 100m LFO module, where feeding the +ve or -ve output into the rate CV input will bend the waveform into non-linear shapes). Unfortunately the Transient CV's will only take 0-5V (you can't have everything!) so some external CV mixing might be needed for maximum flexibility.
the time CV input connects to VR8 (the "time" pot) via J1, both of which are normalled to 5V.
The Level CV input (J2) is also normalled to 5V, but doesn't have an associated pot.
whoop_john
I normally associate the word attenuate with an amplitude adjustment, such as would be used to adjust the Level CV. But your manual relates the word attenuate to the Time CV. You may be using the term attenuate to refer to timespan rather than amplitude, or it may be a mistake in the manual. I was just asking for clarification.
fitzgreyve
attenuates the incoming CV.
whoop_john
Gotcha now smile
cjnuk3
Hi, late to the party as usual! Are the pcbs, panel and PIC still available please? I'm happy with a beta pcb.
Many thanks.
fitzgreyve
Many thanks.
PM'ed
5600synth
whoop_john wrote:
I can confirm that this is a great transient generator and can be set to play 3 note arpeggios because the start, hold and end levels can be set. The original had a system where a quick tap would trigger the loop mode and a longer one wouldn't.
Interesting thread, a bit late, but some thoughts (built my 5600 in 1979).
The problem with using the original 5600 Transient 'A' Retrigger for 3-note arpeggios was that it forces the final note to have a slope (it uses a dual gang 2M2 pot for separate delay/slope).
I neatly replaced Retrigger switch SW3 sub-min toggle A (two position) with a sub-min toggle F (3 position). In the third position it shorts the slope track of VR1 (pins 1 & 3) so you can have repeating 3-note arpeggios with or without a final slope.
BTW I was never happy with the action of the Transients, the A/B/C stage switching action sometimes seemed a bit fuzzy and not distinct. I solved the problem by inserting 1K5 resistors before the IC6/1 and IC6/2 gate inputs.
Another problem I found was in the Envelope Generator, too often you got annoying clicks if prematurely chopping off previous note. Unlike other envelope designs I have seen, a new note forces the level back to zero before starting new envelope, rather than pick up the level from wherever the last note ended. Solution was to insert a switch to isolate R1 from IC5 pin 2 (which conveniently is via a PCB wire link).
Page 2 of 2
