LZX War of the Ants
Author LZX War of the Ants
FetidEye
What a great module name!!
I hope there will be a Cadet series noise module too!
In many European countries television static noise, or "snow", is described using the visual metaphor of a war between swarms of black and white insects. War Of The Ants is our first dedicated noise and texture generation instrument for video synthesis. At its core is a wideband full spectrum noise generator based on amplification of the avalanche noise characteristic found within certain diodes. With the ability to modify and filter the separate spectral characteristics of horizontal, vertical, and low frequency noise, War Of The Ants is capable of generating textures that range from blinking starfields to buzzing grayscale grain to thrashing clipped snow.
Wideband white noise generator based on Zener diode avalanche noise with dedicated output.
Two voltage controlled filters, tuned separately to the horizontal and vertical frequency ranges. Both filters have high pass and low pass modes, allowing blurring or sharpening of the horizontal and vertical spectral components.
Each filter has dedicated external inputs and outputs, allowing the module to act as a dedicated analogue 2D blur/sharpen processor in addition to a texture source.
Voltage controlled density adjusts the proportion of white and black in the final output texture, as well as providing an external signal source input before the saturation amplifier and filters.
Saturation amplifier allows adjustment from evenly weighted grayscale noise to clipped or compressed response resembling television snow.
Two sample and hold circuits at frame rate and horizontal sync rate create low frequency animation and vertical spectral components for further processing. An adjustable lag speed control adjusts the smoothness of low frequency random voltages.
Signal path performs at high frequency, video rate speeds from input to output.
AC/DC input coupling switches and inverting level attenuators on all voltage control inputs.
nerdware
MY ASS IS BLEEDING
johyde
Can't wait to see this in action. Love video noise!
samn
this will be fantastic for creating texture and filling in shapes, I can't wait!
so cool.
nerdware
https://www.youtube.com/watch?v=ai7giilvtM4
RGB
Looking forward to this.
PixelPeeper
I tried this thing out at control in nyc the other day and it I think the case was running into power issues because it didnt seem to be doing much... really interested in this guy tho
samn
here is a vid that might show some more!
PixelPeeper
love down with that noise steeze
Jasper
Thx for the viddy Sam! Got me to pull the trigger smile
paup
yeah sam, you've been killing it with those videos much appreciated!
samn
thanks everyone smile I'm really excited to get more out to you!
