disting mk4 audio recorder question
Author disting mk4 audio recorder question
Waredgo
OK, got the audio recorder to work just fine.
But it seems that you can't play it back using the disting?
It just doesn't play using any of the playback algos.
Did you add the filenames to the playlist?
Waredgo
Thanks Os, I had thought that they were added automatically, so that's the problem. As a suggestion, would be great if a playlist could be generated automatically and updated as each recording is made. That way, one could put in a blank card and make multiple recordings to playback immediately.
Do you think that's possible?
It's possible.
Until then, you could just make that playlist ahead of time. You know what the filenames are going to be. Filenames in the playlist that don't exist yet will just be ignored.
ForAiur
Was that function ever added? Would be very cool.
Not yet.
sytnax
Is audio recorder mode available on Disting mk3?
Yes.
http://expert-sleepers.co.uk/distingmk3sdplayback.html#audiorecorder
disquiet
This is probably a silly question, but in order to get audio off a MK3 and into my laptop for editing, it’s necessarily to take the module out of the rack to access the card, right? Thanks.
Yes, unless you use an SD card socket extender cable to bring the card to the outside of the case.
disquiet
Excellent. Thanks. That sounds like a good solution.
