Roman's Easel PSU 211 PCBs - Sold Out
Author Roman's Easel PSU 211 PCBs - Sold Out
captnapalm
I have some of these available individually, either bare PCBs or stuffed with components. They provide all the voltages needed for a 208r/218r (+/- 15V, +5V, +12V) at a much lower cost than the Cincon converters. A 12VDC brick is required to power.
***Update 6/16/17***
I only have a few of these left and I need to keep them for my own builds, so for now I don't have any more available.
captnapalm
gkalis wrote:
whats this?
It's a pcb to supply power to diy Easels and other small systems.
ArguZ
Can this be mounted underneath a 208 in a standard boat ?
captnapalm
I don't think there's enough room for anything under a 208r2 in a 3" deep boat. Not sure about a BEMI 208 though.
meatcliff
got one of these from captainnapalm... shipped very fast!
if you cut off the end with the edge connector it will fit under the sequencer side of an 208r2 comfortably.
Pailo
I have one reading 11.87 on the Plus. which is supposed to be +15.
anyone build one, or have any insight on a fix?
Thanks for any help.
captnapalm
every problem i’ve seen so far on one of these (including a couple of my own builds) was caused by either a soldering problem on IC3 or a blown IC3.
