Quad VCA anyone?
Goto page Previous  1, 2, 3, 4  Next [all]
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Mattson Mini Modular
Author Quad VCA anyone?
mmm
yummm!
Last Visit: 18 May 2013
PostPosted: Sat Jul 03, 2010 3:51 pm    Post subject: Reply with quote Add User to Ignore List
OK, I think I posted it clearly.
Let me know if I confused everybody.
G
George
http://www.mattsonminimodular.com
patchdub
Last Visit: 22 May 2013
PostPosted: Mon Nov 15, 2010 2:24 am    Post subject: Reply with quote Add User to Ignore List
hi. does the vc mixer still exist in the quad vca board? meaning, would it be possible to still have the the summed out and inverted out along with the individual outs of the quad vca?
as soon as i collect enough green tickets i am ordering the quad vca and the quad ad/asr!
must get food and firewood first though. trying to keep my priorities straight.
www.patchdub.com
http://patchdub.bandcamp.com/
http://soundcloud.com/patchdub
BananaPlug
Last Visit: 20 May 2013
PostPosted: Mon Nov 15, 2010 8:00 am    Post subject: Reply with quote Add User to Ignore List
No but you can accomplish that easily with a small add-on as done here very neatly by negativspace.
mmm
yummm!
PostPosted: Mon Nov 15, 2010 10:12 am    Post subject: Reply with quote Add User to Ignore List
Food and firewood. very frustrating Thanks for the reminder. thumbs up
The Quad VCA is essentially the same circuit as the VC Mixer.
It's easy to sum the outputs of the IC's and run a normal and inverted buffer amp for the outputs.
The problem was, to get individual outputs, I had to split the common output between the amp outputs and run them into individual output buffers.
So, I had to add two more op amps to turn the VC mixer to a quad VCA.
Any summation and inversions would have to follow the channel buffers.
Best to do it the way negativspace did as BananaPlug suggested.
G
George
patchdub
PostPosted: Mon Nov 15, 2010 12:13 pm    Post subject: Reply with quote Add User to Ignore List
okey dokey! i was just looking at bananaplug's panel last night.
thanks!
www.patchdub.com
patchdub
PostPosted: Thu Dec 09, 2010 2:43 am    Post subject: Reply with quote Add User to Ignore List
is it possible to get the pcb without the on board gain trim pots so that i can then put them on the panel?
i'm trying to figure out if i can put the vca and the quad vca on a 2u motm style panel.
www.patchdub.com
mmm
yummm!
PostPosted: Fri Dec 10, 2010 12:11 pm    Post subject: Reply with quote Add User to Ignore List
Sure. But, I'll have no way to test it. I certainly won't be able to calibrate it. Dead Banana
George
patchdub
PostPosted: Fri Dec 10, 2010 7:37 pm    Post subject: Reply with quote Add User to Ignore List
oh. bad idea then? i thought perhaps there might be a benefit to have the gain on the front panel.
www.patchdub.com
mmm
yummm!
PostPosted: Sat Dec 11, 2010 12:18 pm    Post subject: Reply with quote Add User to Ignore List
Not a bad idea at all. The trim pots adjust the gain per channel from crap to "slam the rails". There is also a trim pot for adjusting the internal voltage that gets normalled and cascaded to the CV control input jacks that sets the overall max gain for when there is no CV control input patched into the jacks.
You can set them globally to be a set gain with no CV input to be either a unity gain attenuator or a x gain preamp with no CV and set the channels to be a unity gain VCA or, each channel can have it's own unique gain setting.
I just set everything to unity gain across the board because that's what people are instinctively expecting. But, yeah, determining your own gain specs for your needs is OK.
I have mine set up to be 2X gain for individual CV or audio preamps with no CV patched in and, unity gain VCA's responding to 1:1 input to output ratio with a 5V CV patched in. That way, I have a quad VCA or four preamps in case some of my signals need a boost. If I need a couple of preamps AN a couple of VCA's, I used the patched CV on the higher channels numbers for my VCA channels and leave the lower channels numbers attached to the internal voltage in the cascade for the preamps.
Without the trim pots on the board, I can't verify that the board is operational before I send it.
But, nothing says you cant unsolder them and remote them to the front panel if you wish.
I could just "tack" them in enough to make connection and verify operation and not be a SOB to remove....
So, if you replace the 5 trim pots with panel pots remoted to the main user panel, it gives you real-time control of the gain structures.
Since these will amplify big time, you can use two channels, one to slam the rails (thus clipping at the power rails) Thus, distorting the hell out of the original signal and send that to another channel to attenuate the power-rail slammed distorted signal back down to the +/- 5V that should be.
By using the levels properly and being creative with the CV configurations, the module can become a voltage controlled distortion.
OK, My brain has rambled enough.
Keep in mind, I'll be closing the cart just before Xmas and not accepting any new orders until I re-configure my cost structure. Then, I'll re-open the cart in January with the new prices sad banana
But, only one person has used the newcust5 5% discount coupon that is awarded by registering on my cart.
Everybody except one person has the opportunity to grab whatever they've been musing over and grab 5% off before I close the cart for the holidays.
G
George
patchdub
PostPosted: Mon Dec 13, 2010 12:53 am    Post subject: Reply with quote Add User to Ignore List
nice! thanks!
well i'm gonna be #2 to use the customer discount then!
www.patchdub.com
patchdub
PostPosted: Mon Dec 27, 2010 3:25 am    Post subject: Reply with quote Add User to Ignore List
put together the quad vca today. i went from 2 vcas to having 6! i'm starting to see why people are always saying you can never have enough vcas. lots of fun...
i made a temporary panel out of a piece of 8th inch plywood while i wait for blanks to come from bridechamber.
www.patchdub.com
mmm
yummm!
PostPosted: Mon Dec 27, 2010 10:19 am    Post subject: Reply with quote Add User to Ignore List
Having those global and individual channel gain settings on the panel should add some additional "tweaking" fun. It's peanut butter jelly time!
George
patchdub
PostPosted: Mon Dec 27, 2010 2:23 pm    Post subject: Reply with quote Add User to Ignore List
really really fun! this is opening up a whole world of tweaking.
i did however miss read your wiring diagram and my pots are all backwards. oh well, i'll fix that booboo when i get my panel.
www.patchdub.com
patchdub
PostPosted: Thu Dec 30, 2010 12:14 am    Post subject: Reply with quote Add User to Ignore List
seriously fun stuff. i've spent hours just running vcos into the quad with an eg or a lfo and overdriving different channels. sounds really good.
contemplating another...
www.patchdub.com
mmm
yummm!
PostPosted: Thu Dec 30, 2010 12:25 am    Post subject: Reply with quote Add User to Ignore List
You are now officially playing around in no mans land. I've never tried real-time gain changes on those.
Rockin' Banana!
George
patchdub
PostPosted: Thu Dec 30, 2010 12:39 am    Post subject: Reply with quote Add User to Ignore List
it is pretty awesome sounding. haven't felt the need to break out a filter in awhile. all the adjustment options color the tone so nicely! w00t
now how is that fiy sequencer coming along? hyper
www.patchdub.com
mmm
yummm!
PostPosted: Thu Dec 30, 2010 12:58 am    Post subject: Reply with quote Add User to Ignore List
Cool. headbang
Where's the LMFAO emoticon??????????????????
George
emdot_ambient
PostPosted: Wed May 04, 2011 9:04 pm    Post subject: Reply with quote Add User to Ignore List
So my quad VCA PCB came in today...beauty!
...then I have to look here and read about front panel trimmers... eek!
I'll look at it 'cause that sounds too tempting to pass up!
"None of your five bar gate jumps and over sort of stuff."
patchdub
PostPosted: Wed May 04, 2011 9:07 pm    Post subject: Reply with quote Add User to Ignore List
highly recommend it!
www.patchdub.com
mmm
yummm!
PostPosted: Wed May 04, 2011 10:44 pm    Post subject: Reply with quote Add User to Ignore List
Sorry it took so long Mr. Green
George
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Mattson Mini Modular All times are GMT - 5 Hours
Page 3 of 4
