Author |
English Tear with Metasonix R-55 |
br>EPTC |
br>Almost called this "English Tear with Metasonix Gear" but that'd be a painful unintended rhyme!
I'm looking at the English Tear to specifically interface the R-55 with pitch CVs from sequencers and keyboards.
I don't need it to be in tune or even follow chords, just have discernible changes in sound from note to note.
- Has anyone used English Tear with an R-55?
- I know the R-55 has a limited range so I'm wondering how easy it is to configure, if needed.
Other option is the Expert Sleepers Disting (mk3 or mk4) but I'd really love the ET to work instead.
THANKS for any insight on this. br> br> |
br>CopperHydra |
br>I haven't used an English Tear nor a disting, I only have an ES-4 and an ES-8 but the easiest way BY FAR to get the R-55 to track is to patch a Square Wave to it's Pitch Input.
The range is decent. Anything you need over 3khz can be added in to the signal if you really need it ex:
12khz sinewave from another oscillator ---> Mixer <--- R-55 1.5hkz
R-55 space taking letters for this to fit ---> Wavefolder ---> Mixer <--R-55 (mult output) br> br> |
br>EPTC |
br>CopperHydra: Thank you!
I opted instead for an Acidlab MS2 (which was fairly tricky to find but I love the limited function; just does cv-hz conversion exactly just like a Korg MS-02) - working very well but it did take a minute to find the ranges.
Way I'm doing things:
1) Gate of sequencer into R55 VCA
2) CV of sequencer > attenuator > slew > MS2 into R55 input
(attenuation and slew help calibrate the inputing CV for conversion)
3) R55 out to RK3 for waveshaping - Mixer
Sounds really sizzling and terrific.
I do notice the R55 has a little more teeth in its waveform with straight CV (no Hz conversion) but you lose the variety of pitch variation; so I have a switch set up to jump from the MS2 to a straight CV input of a square wave back and forth. This stuff is so great to work with; I love the process of thinking about it. br> br> |
br>metasonix |
br>The best way to make a thyratron VCO track (""track"") is with a short pulse waveform from a regular vco, then adjust the volume of the pulse for "best results" whatever that is.
I need to post something about Ethan's comic site on Facebook...."Trump Tracts" didn't get enough attention last year. br> br> |
br>Yes Powder |
br>I use an English Tear with the R-55 and R-54. It works reasonably well, but its Exponential Converter's idle voltage (i.e., 0V in) is a bit high for the R-55 so you'll need to apply a little negative offset to its output; otherwise, you'll only be able to get 5 or 6 semitones out of it at best.
With negative offset applied, you should be able to get 2 octaves and change. br> br> |
br>EPTC |
br> metasonix wrote: | I need to post something about Ethan's comic site on Facebook...."Trump Tracts" didn't get enough attention last year. |
Hey Eric - Thank you! - I somehow missed your comment here. Much appreciated.
The Tracts did get some decent footing for a few months. When Jack Chick died in Oct 2016 there were a few obituaries in Religious media (and elsewhere) - Hilariously, CBN (Christian Broadcasting Network) actually linked to the Trump Tracts as an example of modern parody of Jack Chick's work and linked to my site in print. That story got picked up into a bunch of other papers. I made twelve tracts in total, http://www.ep.tc/trump-tracts/ - But really couldn't manage to do any more of them. I know I had a good opportunity at wider success to keep making tracts after he was elected, but the misery of thinking about him was too grim to consider. Trump is almost impossible to work with as a subject. Made some good jokes, though. The aristocrats piece is probably the best one.
More appropriately for this forum I'm working on a track-a-day album called THE BUREAU, which uses a lot of Metasonix. (R55, R51, S2000, D2000, R55, R56, RK2, RK3, RK5) - There's a daily thread on MW here:
https://www.muffwiggler.com/forum/viewtopic.php?t=193985
Here's the most abrasive track of the album so far, "Susan's Paperwork", which is all Metasonix, feeding an R55 into RK3 - uses the Acidlab MS2 and its handy frequency and width knobs to lessen/widen the signal going into the R55.
[s]https://soundcloud.com/eptc/the-bureau-014[/s]
Thanks again, EP br> br> |
