Doepfer A-151 Sequential switch for video.
Author Doepfer A-151 Sequential switch for video.
n167tx
Hi guys.
Have a gig next month and this could be really useful.
Would the Doepfer A-151 Quad Sequential Switch work for video ?
For sequencing a NES, SNES and other circuit bent stuff?
Using one of this RCA adaptors ?
http://www.ebay.co.uk/itm/3-5mm-MONO-Mini-Jack-Plug-to-RCA-Phono-Femal e-Socket-Audio-Cable-Adapter-/331964755810
http://www.doepfer.de/a151.htm
tenshun
Hello, the A-151 will work.
Well i actually use it with the visual cortex and patch each of the ramp outputs into each of the A-151 inputs.
i then run it at audio rate to make crazy patterns and use a random trigger to reset it.
I have not tried it yet with video signals. i guess its worth a try!
n167tx
Perfect thanks.
I just ordered one. they are pretty cheap.
I will report back here how it works with a little video.
Thanks tenshum
Dirty_Bill
It will work with video signals inside an LZX system, which do not have associated sync signals embedded, as tenshun mentions.
Using them with full bandwidth composite video will likely give you a very blurry, glitchy mess. But that may be your intent!
337is
tenshun wrote:
Well i actually use it with the visual cortex and patch each of the ramp outputs into each of the A-151 inputs.i then run it at audio rate to make crazy patterns and use a random trigger to reset it.
Great tip, thanks. Keen to try this with mine. thumbs up
