Using DJ Mixers with modular
Author Using DJ Mixers with modular
witchbutter
I started as a DJ before I began composing electronic music, so I have a strong familiarity with DJ equipment. I am now using 2 eurorack cases each with their own character and I'm beginning to wonder about integrating these 2 with a DJ mixer. DJ Mixers have performance oriented features like simple filters, eq kills etc which are not on studio type mixers and are typically more tightly spaced. So given that I have enough pre-mix capability in my eurorack cases already is there anyone out there using a DJ mixer effectively for performances? What about integrating eurorack, ableton and a dj mixer together? What limits do you encounter?
moremagic
ive never used ableton, but i do love using my dj mixer with my synths. one fun thing is to patch up something on my euro to be played with the keyboard on my mono/poly, then feed the korg and the modular to the dj mixer and play the crossfader. its kinda like super basic 2 channel vector synthesis and i find it a lotta fun
nickgrys
I use a Xone 92 with my 6U rig and TR-09 - 3 mixer channels for the modular and 1 channel for the drum machine. I use the aux sends/returns with guitar effects pedals.
ben_hex
Check out phil "VCOADSR" using the new Allen & Heath / Hawtin Play differently.
Performance -
https://youtu.be/5Wrv9W-B728
Rig rundown -
https://youtu.be/OlZ3E_w7Kfw
witchbutter
That mixer model 1 is a beautiful piece of machinery, even at $3200. I have a Pioneer DJM-S9 I'm currently working with, hoping I can make use of the sampler buttons.
Performance -
Rig rundown -
I was thinking the Model 1 would be an excellent performance mixer for hardware.
I feel sorry for VCOADSR though - nothing worse than playing to a rigid audience, I guess the place didn't really have a dancey vibe.
ben_hex
dubonaire that was Modular Meets Leeds. So a big synth nerd event. Not really a crowd for "getting into" any particular style. The reception afterwards was great. Funny though as I imagine a lot of the crowd were really into what he was using and how he was doing it as much as the music. Where as in a club he'd have the opposite effect.
docsample
Would be good to know how he routes the audio into the mixer, including the send and returns. Like is it straight up, vca to audio in or what? Don't want to nuke my xone 92.
The gain trim pot on the Xone 92 can attenuate level by -10dBU which should adequately reduce your euro inputs. Actually manual says -15db in one place and -10db in another. You should be OK. If you want to be careful select post-eq cueing, turn down your trim pot fully, turn down your eqs, turn down your fader. Connect a signal from your eurorack and gradually turn up the eqs and watch for redlining on the channel meter. Then with the EQs at 0db adjust the trim pot until you get the right amount of gain so that you are +/5db around 0 on the meter.
But you should have at least a limiter between your euro signals and the mixer to avoid out of control peaks. I think VCOADSR is using an ER-301 as a limiter.
Personally I would use in/out amplifier/attenuator modules but that's just me. I would be happier with that in a live rig. I know a lot of people feed their euro signals straight into audio cards.
I think the PLAYdifferently mixer accepts hotter signals than the Xone 92.
docsample
awesome thanks for the reply! that helps a lot and i will check the manual.
you're welcome, let us know how it goes.
Ypsi Kid
Hey man,
I started out as a DJ as well and then moved into production. Used Ableton since about 2000 and now am using Ableton, my modular and the Roland MX-1. While not really a DJ mixer per say, it has functions like a DJ mixer and I use it as such when playing with the Modular. So I think I'm doing something similar to what you are doing and loving it. Brings the familiarity of the DJ mixer so I can fall back to cutting EQ's, Channels and efx for performance and it works great! I have a thread here - https://www.muffwiggler.com/forum/viewtopic.php?t=202449 - where I'm documenting my journey to putting a live set together. It will give you an idea of the sound of what I'm doing anyway.
I use Ableton mostly for efx and some grouping of tracks for side-chaining and other efx. Ableton works as a master clock as well for everything. I'm sequencing completely outside of the box along with all my sound sources and modulation. So Ableton is really just acting as throughput for everything into the Roland MX-1 (along with efx). I will most likely also use it to fire off some loops (drums) in the future, but I find the BitBox is like my rack version of Ableton - it plays the part for samples and loops (and it can record perfectly cut loops, although I'm not using it for that.... yet!).
So to answer your question, definitively possible and I would say recommended if you have a background as a DJ. Let me know if you have any questions.
Yep I also use an MX-1 with a small live set up. It's great to use but let down by the number of inputs.
witchbutter
Since I've started this thread I've tried a lot of configurations, but I've really settled into the WMD performance mixer. For my rack it helps all my levels gel using a familiar layout for a DJ, with ways to input pedals and outboard gear. I do still want to integrate my DJ mixer but at this point when I want to take the rack out live I don't really need it. I think most likely if I use a two channel mixer I might have to two separate racks with 2 wmd performance mixers in them run into each side of the DJ mixer, but we'll see.
Selstrom
Me too, and yes I don't have any other Aira or USB equipment so 4 channels are just sat redundant. Although, the powered USB socket comes in handy to power the analog to digital converter that I use to utilise the digital channel.
moremagic
when you pst pics twisted
why not have the modular on one side, WMD Performance and all, and something totally different on the other side, like a poly or sampler maybe
marcmuon
My live performances are typically sandwiched between DJ sets in a techno club environment. I've been sub-mixing the modular out to the Mackie Mix 8 and then taking that output to one channel of a DJ Mixer, usually either Pioneer or Xone 92. Been working great so far and easy to setup quickly.
dekemcculo
the party mix module from casper/bastl seems cool for live/performative mixing (seems exciting to be able to chain them and combo with dark matter too, also in the video)
dekemcculo
(neither are out yet but hopefully soon) ~
