quad slew
Goto page 1, 2, 3, 4  Next [all]
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Eurorack Modules
Author quad slew
Navs
Last Visit: 15 May 2013
PostPosted: Wed Jul 07, 2010 4:34 am    Post subject: quad slew Reply with quote Add User to Ignore List
Repurposing an unused A-180 multiple as a quad passive slew:
http://navsmodularlab.blogspot.com/2010/07/diy-quad-slew.html
smile
https://flavors.me/basicelectricity
dude
fuck yeah!
PostPosted: Wed Jul 07, 2010 4:36 am    Post subject: Reply with quote Add User to Ignore List
more slew!
my bandcamp
other bandcamp
dudetape
no time for love dr. jones
en.
PostPosted: Wed Jul 07, 2010 5:27 am    Post subject: Reply with quote Add User to Ignore List
uhuh! thank you navs and fonitronik!
Smooth Operator
Last Visit: 18 May 2013
PostPosted: Wed Jul 07, 2010 6:28 am    Post subject: Reply with quote Add User to Ignore List
Great idea! thumbs up
Monobass
thonk.co.uk
PostPosted: Wed Jul 07, 2010 7:14 am    Post subject: Reply with quote Add User to Ignore List
brilliant.. am I right in thinking the A180 has no other components, purely ganged connectors? If so then this is a very simple DIY project without an A-180 also.
fonik
PostPosted: Wed Jul 07, 2010 7:57 am    Post subject: Reply with quote Add User to Ignore List
absolutely, monobass.
it is actually nothing but a fixed lopass filter. there are quite a few passive module designs you could easily build as a start. what about a switch to select from different cap values? this would give you a passive 6db lopass with selectable cutoff (has been made by moog in the past millenium wink - see below). or what about fixed hipass, attenuators, multiples, switches (selectors)... all you need is a cheap soldering iron from the hardware store, believe me, it is sufficient for a start.
anyways, navs module will be very useful for everyone who frequently uses gates for VCAs...
cheers,
matthias
www.modular.fonik.de
www.fonitronik.de
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids)
stk
PostPosted: Wed Jul 07, 2010 9:26 am    Post subject: Reply with quote Add User to Ignore List
Could this be modified to use a pot for variable cutoff/slew?
new terminal sound system 2xlp/cd/digital out now | soundcloud / antisound.net | my modular
"This place is a giant "fuck you" to that system, to that attitude, to that pedagogy. ... We are winning! And only by remaining free and open do we maintain that position. For you, and for me, and for the children. For the music." - Muff Wiggler
fonik
PostPosted: Wed Jul 07, 2010 9:33 am    Post subject: Reply with quote Add User to Ignore List
no, actually not.
by replacing the resistor with a pot you would not just change the slew rate but also change the level. in other words, the slower the slew the lower the signal level. for your ears the lowering of the level would simply whitewash the effect of changing the slew.
to prevent this you would have to use opamps as buffers, thus having an active module.
as i mentioned above you could use a switch for selecting capacitors of different values (as seen on the moog schematic above). the larger the cap, the slower the slew...
cheers,
matthias
www.fonitronik.de
fonitronik at
haesslich
Last Visit: 17 May 2013
PostPosted: Wed Jul 07, 2010 9:52 am    Post subject: Reply with quote Add User to Ignore List
with a 4051 and a counter you could replace the switch by a trigger signal... okay, again this would be an active module ;-)
stk
PostPosted: Wed Jul 07, 2010 9:58 am    Post subject: Reply with quote Add User to Ignore List
Thanks for the info, fonik.
itijik
Three eyed monster
PostPosted: Wed Jul 07, 2010 11:12 am    Post subject: Reply with quote Add User to Ignore List
This is nice. I was thinking that this would be perfect to use with the A160-161 outputs! hyper
(oh, you mention the RCD on your article...YAH!)
itijik
Three eyed monster
PostPosted: Wed Jul 07, 2010 2:14 pm    Post subject: Reply with quote Add User to Ignore List
Are the values used for this filter the same values used on the fonik mixer, heard here?... http://navsmodularlab.blogspot.com/2010/06/patch-tips-11-ac-coupled-mi xing.html
fonik
PostPosted: Wed Jul 07, 2010 4:24 pm    Post subject: Reply with quote Add User to Ignore List
no. far from that. in fact it is a different configuration. the fonitronik attenuverting mixer uses a highpass configuration to remove offset.
and it uses a 22uF, that gives much longer times anyways.
nav wanted to remove the 'pop' of the VCAs caused by those steep rising edges, so he wanted to smooth them just a little bit. yo won't even recognize it on slowly changing CVs.
cheers,
matthias
www.fonitronik.de
fonitronik at
Monobass
thonk.co.uk
PostPosted: Wed Jul 07, 2010 4:59 pm    Post subject: Reply with quote Add User to Ignore List
I like the idea of making some manual switches with adjustable slews smile
itijik
Three eyed monster
PostPosted: Wed Jul 07, 2010 5:30 pm    Post subject: Reply with quote Add User to Ignore List
Thanks fonik!
dequalsrxt
PostPosted: Wed Jul 07, 2010 5:54 pm    Post subject: Reply with quote Add User to Ignore List
that'd be nice to do to one of the sets of multiples on the 1u modular world utility strip... might have to do that. cheers! Guinness ftw!
fonik
PostPosted: Thu Jul 08, 2010 12:55 am    Post subject: Reply with quote Add User to Ignore List
the values from the moog module are for audio, primary. you may want to try different cap values for CV.
cheers,
matthias
www.fonitronik.de
fonitronik at
DGTom
Last Visit: 10 May 2013
PostPosted: Thu Jul 08, 2010 6:50 am    Post subject: Reply with quote Add User to Ignore List
Great use for a "useless" module hihi
For "random" slew, use an LDR instead of a normal resistor (or in parallel)
Bend the LDR so it faces inside the case or towards the crack in between modules for differant amounts of "random"
@Navs; have you tried stacking multiple RCD outs into the input?
[Djo]
PostPosted: Fri Jul 09, 2010 10:17 am    Post subject: Reply with quote Add User to Ignore List
Thank you for this tip navs!
I made mine with a switch. I use 1µ and 4.7µ.
Edit : 4.7µ is too small, I put a 6.3µ on parallel and it's great. wink
Sound example :
Soundcloud A180 Mod Slew
en.
PostPosted: Fri Jul 09, 2010 2:58 pm    Post subject: Reply with quote Add User to Ignore List
it could be nice also with a three position selector 1-off-2
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Eurorack Modules All times are GMT - 5 Hours
Page 1 of 4
