feedback sound of guitar without a guitar
sleestack808
Post by sleestack808 » Fri Sep 08, 2017 4:01 pm
I want to get a nice droning feedback sound like a guitar, but avoid the guitar. Is there an invention i dont know about?
I have a barcus berry pickup and a zither. but id like to get a nice thick sound. Thanks..
I know buy a guitar.
sduck
experimental use of gravity
Post by sduck » Fri Sep 08, 2017 8:05 pm
Get a mesa boogie Mark IIc+. And a gibson ES335. Or something similar. But whatever you do, do NOT refer to it as a guitar. It is not a guitar. It's an electric tenor zither. Or something like that. Problem solved.
dkcg
Post by dkcg » Fri Sep 08, 2017 10:40 pm
You still need a guitar, but an ebow can do this.
grimleyj
Post by grimleyj » Fri Sep 08, 2017 11:06 pm
Anyone tried a Digitech Freqout?
abandonist
Post by abandonist » Sat Sep 09, 2017 12:27 am
A hot mic with a distortion pedal behind it can controllably feedback pretty well. You just move the mic around as needed.
sleestack808
Post by sleestack808 » Sat Sep 09, 2017 10:56 am
I have a nice tele. Im just afraid the guitar mentality will mess with my creative mind
sleestack808
Post by sleestack808 » Sat Sep 09, 2017 10:59 am
EBow, nice idea, thanks
smetak
Post by smetak » Sat Sep 09, 2017 11:50 am
grimleyj wrote:Anyone tried a Digitech Freqout?
I did.....hum....didn't really cut it for me. Although I am digging the recent Digitech effects - got the very fine Obscura delay, which is on my board - the Freqout was a bit of a let down, sounded like a watered-down flute. Maybe I got the settings wrong while horsing around with it (didn't really have too much time on my hands when I tried it while on a trip to NY) - but didn't really cut it for me.
For something similar, an Ebow is hard to beat.
e-grad
Post by e-grad » Sat Sep 09, 2017 12:16 pm
Experiment with a fixed filter bank in the feedback loop of the A199 Spring Reverb. Try a rather complex input signal. This should get you in similar territory even though it is not the real deal. :bananaguitar:
sduck
Post by sduck » Sat Sep 09, 2017 3:24 pm
sleestack808 wrote: Im just afraid the guitar mentality will mess with my creative mind
Say what? It's just another tool for your creative mind. Unless your creative mind is closed, in which case a good dose of feedback might help crack it open a little...
Extra tip: to get away from typical guitar feedback sounds, detuning is your friend.
Just me
Has enough VCA's
Post by Just me » Sun Sep 10, 2017 8:50 am
I have a patch I made on my Minimoog Voyager that does the harmonic feedback thing pretty well. But, I have a Telecaster, Jaguar and SG along with a selection of amps that do it even better.
If I have water in my ear, is it safe for me to listen to electronic music?
GuyaGuy
Post by GuyaGuy » Sun Sep 10, 2017 5:40 pm
Wonder how this works with other instruments...
http://en.m.audiofanzine.com/other-guit ... 14551.html
controlFreak
Post by controlFreak » Sun Sep 10, 2017 10:46 pm
make a feedback loop:
mult a guitar fuzz pedal's in and out and maybe add an eq or filter in the loop to alter the resonant frequency then take the signal out from the mult.
Will work best with pedals that don't invert the signal. Inverted signal would mean negative feedback... but may work as most pedals are very imperfect.
mt3
Post by mt3 » Tue Oct 03, 2017 2:21 pm
Look into no input mixing.
stk
Post by stk » Wed Oct 04, 2017 7:28 am
Tell it brother. :sb:
mt3
Post by mt3 » Thu Oct 05, 2017 4:43 pm
koyl
Post by koyl » Wed Oct 11, 2017 5:04 am
Yes, it works great for traditional feedback and beyond (like getting feedback with a clean sound :hihi: )
indexofmetals
Post by indexofmetals » Thu Oct 12, 2017 12:58 am
Macumbista Soundbox. Running several together is even better.
noisejockey
Post by noisejockey » Thu Oct 12, 2017 8:54 am
Just actually make feedback with your zither.
Mic the zither with a second, actual/non-contact mic. Feed mic into preamp. Feed output into an amplifier...but a small one, like the little Pignose amp, or those 7" high Marshall stacks, or a MiniRig. Place the amp with the mic pointing a little towards it, place it close enough to feed back, find the sweet spot where the feedback builds when you really hit or strum hard. Track that mic alongside the BB contact mic, mix to taste.
And try putting an eBow on it. Maybe the strings' metal cores will be activated by it.
koyl
Post by koyl » Thu Oct 12, 2017 9:16 am
I just remembered I got excellent results with a M.I. Elements feedbacking on itself. It's like having Thurston Moore trapped in your modular. :miley:
Rex Coil 7
Re: feedback sound of guitar without a guitar
Post by Rex Coil 7 » Thu Oct 12, 2017 10:07 pm
sleestack808 wrote:I want to get a nice droning feedback sound like a guitar, but avoid the guitar.
Use a synthesizer.
sleestack808 wrote:Is there an invention i dont know about?
Synth-uh-sizer. Say it with me now ..... synth ...... a ...... sizer. C'mon .. you can do it .. I know you can!
sleestack808 wrote:I know buy a guitar.
NOT A GUITAR! SYNTH! BUY A SYNTH! :msnsmack:
Poking fun aside, I recently purchased a Kurzweil PC3A6, and it has some PSYCHO-SICK-ASS lead synth sounds with the added dimension of amp feedback. Rolling the mod wheel upward brings in the screech ... tweeking one of the slders tunes the screech in hz producing some beating, tweeking another one of the sliders adds a sub-octave to the screech, giving it that pinch harmonic sound. And tweeking yet another slider adds some form of ring modulation to really make it rude as hell when the mod wheel is rolled in and the screech makes enemies of all who dare to defy it's mightiness.
The pinch harmonic thing is quite musical and highly effective. Nice job on that program.
:tu:
maltemark
Post by maltemark » Sat Aug 17, 2019 4:51 pm
Anyone using a freqout with synth fx/euro?
Feel free to use my old samplepacks: https://freesound.org/people/altemark/
