STEFFCORP - 2600 VCO
Author STEFFCORP - 2600 VCO
steffensen
Hey peeps,
I figured we could use a build-thread for the new 2600 VCO
Here is some text and links!
The Steffcorp 2600 VCO is an analogue oscillator with full voltage control based on the 4027-1 ’VCO-2’ oscillator used in the ARP 2600.
It’s not just a copy however, we have gone to great lengths to bring it into the 21th century.
A much needed precision reference voltage was added, as well as buffers and a few other goodies.
Going SMT offered the means of improving the PCB-layout even further, as well as a selection of easy-to-source parts. No more treasure hunts and extravaganza prices.
On top of this, a good bit of time was spent on analyzing and comparing modern parts to find the best matches of the original part specifications.
BUILDGUIDE
Available at Modular Addict and DIYsynth
Thanks for reading!
heapish
Nice, everything looks pretty easy going too! The hardest parts being Q1 with the small pitch and the electrolytic smd. But they're still easy enough.
Silicium
Hey steffensen,
do you have some THT pcbs left?
I still have some rare parts left which i would like to bring into one or two additional 2600 VCOs!
steffensen
heapish
Yes, super easy build actually! Even Q1 is easy with some flux.
Same goes with the electros imo. But i might just been lucky thus far. razz
Silicium
No THT left. It's all SMT now.
Once i gave it a go i realized how fast and easy it was!
That said, i might release the older THT designs in some version in the future.
LED-man
If needed I can preassemble the ICs and Q1
ZZ Ardoz
Just ordered my parts - looking forward to this
ZZ Ardoz
Man - just built mine - sounds incredible!!
steffensen
Glad you like them!
dksynth
any hints about getting that panasonic tempco? seem to be out of stock everywhere. I could kludge in a THT 1.8k 3300ppm part I suppose.
ZZ Ardoz
send Rickard at Steffcorp a request, he might have a few more available
technotron
Amazing VCO - highly recommended!
truman_k
any chance of getting a second batch of stock?
steffensen
technotron
Thank you!
truman_k
PCB's are in, just awaiting some panels too!
truman_k
steffensen wrote:
technotron
Thank you!
truman_k
Great, I missed the first batch
truman_k
truman_k wrote:
steffensen wrote:
technotron
Thank you!
truman_k
Any news about the availability of this VCO pcb?
steffensen
truman_k
Sorry, been on xmas holiday.
Feel free to ask your local dealer to stock these ( cool ), else I'll sort you out myself.
Email me through the website and I'll do it asap!
truman_k
I have finished mine 2600 VCO, it sounds great, very powerful.
Everything works out just fine. Except the SINE wave doesn't look like a SINE wave, it comes out just like the triangle wave. I tried to trim it using the two trimmer, SINE purity and SINE gain, but it still didn't change to the SINE shape. hmmm.....
Which part of the circuit should I checked out for the problem? I have looked closely at the circuit around the two trimmers, didn't seem to have any bridges or solder break points at all. Dead Banana
truman_k
repeated
steffensen
truman_k
Your build looks excellent. I don't think there's anything wrong here, just a matter of trimming it right.
The Sine converter works by amping the input to the JFETs until they saturate, and simultaneously lowering the output gain as it would clip a lot.
Try this first and let us know how it goes.
truman_k
steffensen wrote:
truman_k
Yes, you are right, thanks for the help. I just don't know how to trim it right. Now with your guideline, it looks and sounds like a sine now. Great VCO, I would like to get another one soon.
steffensen
truman_k
Great! I'm glad you enjoy it. :-)
evengravy
Hey Steffensen. I've built three of these and it all went pretty smoothly, well laid out design. On only one of the units I have no saw output but all other functions work as expected. Could you give me some tips on the parts to inspect for such (nothing obvious from visual inspection)
Thanks,
steffensen
evengravy
Hm, you say all other functions are working, but how is that possible if you have no Saw? All waveforms are based from the Saw.
Measure with a oscilloscope around the LM3046 and tell me if you get a saw-like waveform on any of its pins.
evengravy
Okay, yes saw core, I should have known. Yep nothing from the saw output, it could be as simple as a dodgy jack or the soldering of. I'll get a look and scope the path if nothing obvious shows up. Thanks,
