VDD Dual Symmetric Output Module
Author VDD Dual Symmetric Output Module
LED-man
My Friend "VDD" from Germany designed with me 10 Modules,
one important thing was to give you the chance to DIY our Modules.
MU Format Modules Kits are available soon (depends on demand)
I offer in my Shop, different Versions,
pcb only
pcb + Panel
Fullkit
Assembled Version
https://www.DIYSYNTH.de
We started last week the release of this module:
The VDD 5002-01 Dual Symetric Output Module:
5002-01 Description
The 5002-01 is a module to convert standard synth outputs into a balanced signal. This is helpful in live and studio situations: balanced signals are more robust to interferences and it is possible to use long cables without signal degradation.
Your modular synth is an unknown source. This is why we designed this module not with specific input level requirements.
The 5002-01 is well suited for live situations. The white panel is easy to read even on a dark stage. The 1/4inch connectors are separated from the pcb in order to reduce mechanical stress. As a result, it is easy to maintain. Instead of trying to build it as small as possible the main goal of the panel design was easy operation. So every connector and knob is easy to access without interference with other elements.
The circuit is built with Highend Op-Amps 2x SSM2142 (Line Driver) and NE5532 Opamps.
The Device is designed and built in Germany with respect on ROHS (leadfree solder)
The Module works on -12V/12V and 15V/-15V.
a usage of MOTM (MTA156) connector is possible.
lintfresh
Interested!
PCB only option in the works?
LED-man
lintfresh wrote:
Interested!
If you want I can sell the pcb only, please pm.
Jarno
Looks great, wrt ssm2142, those 10uF are between outs and sense? IIRC they should be NP/BP right?
LED-man
Yes ssm2142 and bipolar caps.
Eric the Red
Those are nice and clean looking panels, and the boards do not look that difficult to assemble.
Great work.
LED-man
i added in my store:
PCB only Version
PCB and Panel
Fullkit
Assembled Module
the Module works on 12V/-12V and 15V/-15V
synthetek
Has anyone built one of these? It looks like the BOM says the 6 100n caps should be ceramic and the 4 100pf should be film but in the picture of the module on the website it shows the opposite?
LED-man
for both capacitor values are polyester or multilayer ceramic capacitors fine.
LED-man
by the way, the PCB + Aluminium Panel price is reduced to 9€ only.
the jacks and pots are available in my shop too.
duff
Bargain!
I have one of these in TTSH and I am very happy with it.
synthetek
