bending wj-ave5 and wj-ave3
Author bending wj-ave5 and wj-ave3
kebab
hi someone have some schematics for bending these two video fx mixer??
kebab
or better diagrams for how to bent it
mrfang
Karl Klomp had a nice tutorial on the AVE3, but unfortunately his site is no longer up.
wednesdayayay
you could always use the waybackmachine site
I just did there is plenty to dig through
https://waybackmachine.org/web/20161016123957/http://karlklomp.nl/pro/ vbend.html#av52
there is one I found in just a cursory glance
kebab
great!
but if you can help me,i dont understand in the pic how the bending points are linked,all the points are linked with the ground? or with others bent points on the ave5??
wednesdayayay
can't help it isn't something I've done at all
I would say poke around his site
check out the pictures
read everything
don't be afraid to break something
snufkin
Kebab be careful the mains on the ave mixers is real easy to touch and they are also really easy to short out.
evolve
Yeah if you need someone to hold your hand on bending a mixer, you are not ready. Start with something that has batteries, like a children's toy.
ch_08
did you make any progress on this bend?
any pictures?
kebab
i've find some bendings point!
one think i dont understand is how(if it's possible)can make react audio for create video reactions...
FetidEye
if you can add a potmeter and it has cool effect, you can try to add a vactrol and control it with CV.
If you want it to react on audio, you will need a envelope follower .
kebab
a vactrol like this?
but what would be the connections that I should do?
maybe between a bending point and the audio-in mic for example?
FetidEye
well, like I said. first try 2 points .
Do you know the "feeler" or "probe" technique?
get 2 pinwires and solder a resistor in between. 1k, 10k or 100k
then probe the circuit. (from bend point to gnd, +5v or another point.
be carefull! You can also do this without the resistor, that takes away the safety.
If something cool happens, mark that point.
then try to solder a potmeter over those 2 points.
if the effect is still cool , mark it for external control.
Sometimes a point can only be switched. add a switch there!
(switches can also be automated. read up on that)
you can make your own vactrols with a LED and a LDR. much cheaper and more fun!
The Mystic circuits 0HP can work, but it is purposed for eurorack signals.
The voltages in the videomixer can differ.
read up on basic circuit bending ! There are a lot of tips to be found
evolve
Kebab, you can use a vactrol like the XVIVE. Check sites like Smallbear.com
There is also this - although the guy who runs the store is a douche
http://store.synthrotek.com/Vac_Pak_Kit
