Audio and Video for Arturia Drumbrute used w Guitar Pedals
MUFF WIGGLER Forum Index -> Your Tunes Here
Author Audio and Video for Arturia Drumbrute used w Guitar Pedals
baxoutthebox
https://www.youtube.com/watch?v=qZIVcNSpHAk&list=PLhPtBydHttS0HRC_yaCb Tlo9sEMWtTS2-
routings:
kick -
db kick signal > jdx direct drive > thru > hi cut eq
db kick signal > jdx direct drive > out > mooer ShimVerb
snare -
db snare signal > red panda particle
clap -
db clap signal > joyo digital delay
mix out -
db mix out
video:
"food dye, glassware and an overhead projector" footage
"drumbrute jam" footage
random altered art from the internet
Adobe Premiere Pro CS6
tony d
Good stuff, definitely sounds better than the videos i've watched with the outs just raw.
Are the pads velocity sensitive ?
Thanks for posting this up, i'm on the fence about this machine.
baxoutthebox
thanks tone, pads are velocity sensitive and capable of sending midi out across a full range of 0-127 but...
as far as playing the drumbrute is concerned, the velocity either controls a normal step or an accent. you can set the threshold for where this is met example:
i play pads soft and am unable to hit the high velocity it requires for an accent so, i changed the default point of change from 90 to 60. now anytime i hit above 60, i get an accent. anytime below, a normal step
tony d
Gotcha, thanks man.
Overall do you dig it?
baxoutthebox
i really do, true analog drum synth with serviceable sounds:
64 step sequencer
polyrhythm
individual outs
two mode filter
all for 300-400 depending how you shop
