Modding Doepfer 138-e to be voltage controlled crossfade
Author Modding Doepfer 138-e to be voltage controlled crossfade
lionelfischer
possible to make the crossfader on each of the 4 units voltage controllable?
http://www.doepfer.de/a138e.htm
lionelfischer
any takers?
nigel
Not by a simple mod, no. You would have to redesign it.
southphillysynths
Yeah it would require each cross fader to be a VCA. There are modules that do this but not possible to mod this one unfortunately.
mskala
Those are special centre-tapped pots. They're even harder to simulate with VCAs than the regular kind. You'd need three VCAs per channel and some clever control scheme that takes into account the different operating modes based on what is plugged in to which of the inputs. (Props for the A-138e, though! It's one of my favourite modules, even if it does have to be manual only.)
lemberski
Found a discussion with a schematic for a 3-way scanner which should be able to replace a center tapped pot:
https://electronics.stackexchange.com/questions/208155/is-it-possible- to-use-a-potentiometer-as-a-dp3t-style-control
