TM3030 PIC Versions
Author TM3030 PIC Versions
J-Acid
I still have the v1.1 PIC in both my TM's, is there any need for me to change it? I read here a while ago V1.2 allows midi control of the filter or something like that?
Any info appreciated...
Synthbuilder
There was a later version that Colin did for the issue 2 and issue 3 boards. Along with some changes to the TM3030 circuitry the new PIC allowed the modulation wheel midi CC to control filter cut-off.
These later PIC versions can be used on issue 1 boards. However, if you wish to make use of the additional filter control you need to add a bit of simple circuitry as shown here:
It is possible to add those three extra components on the underside of the board too without need for any stripboard.
However, the TM3030 is a legacy product and no new boards will be produced. I have asked Colin for some new version PICs for spares but these are not in stock as yet.
Tony
J-Acid
Ok, thanks for the info. Is there any other benefit to having an upgraded PIC?
J
Synthbuilder
I would not have thought so.
Tony
J-Acid
Ok, thanks for the info.........
