µTune question
MUFF WIGGLER Forum Index -> Tubbutec Goto page 1, 2  Next [all]
Author µTune question
Steevio
My µTune arrived yesterday, and I have to say build quality, screen etc. is fantastic.
I'm having a problem, I'm obviously doing something wrong, and cant figure it out.
I'm trying to build a simple scale just to get used to how everything works, and everything seemed to be going well until I tried to quantize a CV input, and nothing happened.
I built a simple harmonic scale with 4 notes, 5/4, 3/2, 7/4 and 2/1, named it and saved it. It appears in the list of scales and when you go to edit, all the notes are there, but when I run a series of CVs into the input nothing happens, the same series of CVs run into a 12TET scale from the SD card works as expected
What am I doing wrong ?
thanks in advance guys,
tubbutec
Very likely this has to do with "scale mapping". You can find the settings under "keyboard mapping" in the config menu. (keyboard mapping will be renamed to scale mapping in the next versions)
Relevant for you are the first two parameters:
Middle Note
and
Middle Vol
This sets the point were µTune starts mapping the scales. In both up and down directions.
Middle note is set to 60 by default, mapped to 5V. This means your scale is repeated from note 60 upwards and downwards. Since your scale is very short (only 4 notes), note number 56 is mapped to 4V, 52 to 3V,... and finally note number 40 to 0V.
This means any note number below 40 will produce 0V. That is why you can not hear any change when inputting low voltages/note numbers
If you work with low input voltages between 0V and 5V, I suggest you set the Middle note and Middle voltage lower. For example 0 and 0V, or 12 and 1V.
This should do the trick for you..
Steevio
thanks for your quick response !
OK so now its responding ( 0 - 0V ) but not to the 4 note scale I set, its running through 3 times the 4 note scale in the Octave, so its 12 notes.
This is how I set the scale;
01 - 0386.3
02 - 0702.0
03 - 0968.8
R -1200.0
I'm obviously missing something. Thanks for your time
tubbutec
Should work this way, can't say why it would not. Will have to test this on Monday and will get back to you...
Steevio
thanks !
timoka
ah great i had a similar problem with the scaling.
so in general, if using analog sequencer or ribbon controllers which mostly start at 0v to 5v or higher, it's best to set everything at 0, middle note and voltage?
is it possible to have this saved as default configuration?
tubbutec
The optimal setting always depends on your preference. Think of the middle note as the starting point of your scale. As mentioned in the manual, this is the point with constant pitch, no matter what scale you are using.
If you have an input range of 0-5V (usually that means note number 0 to 60) you could put the starting point at 0, but maybe 2V / note 24 suits you better. You could then pitch up and down from there..
Steevio
OK so I figured it out, I needed to change the CV input config to 4 notes to get 1V per octave.
So i guess that you need to change this value everytime to the number of notes in your scale, if you want to keep to the 1V /Oct standard.
would there be a way to implement this automatically in a future update ?
In other words a setting which keeps to 1V per octave no matter how many notes in your scale ?
timoka
thanks tubbutec for the answer, it would be great to have the possibility to set our own default values for the scaling and what steevio said above would be great too...an automatic adjustment of the number of notes depending on the scale one chooses!
tubbutec
I agree, will add an 'automatic' option in the notes/octave function. Won't work for midi though
Steevio
awesome.
I dont use midi personally.
thank you !
Steevio
One more question,
I'm assuming its not possible to transpose and scale at the same time unless I use one channel for each process (or am I misunderstanding the manual again)
Currently I use several Doepfer A156s and I find it very useful that I can dual-
transpose and quantise to scale in the same module (although you can only transpose both channels equally, but this isnt an issue)
Would it be possible in a future update to add some way to do this ?
Maybe from the Gate Input sockets? I dont use gating much really, I usually only free-run my quantizers,
Congratulations on a really nice module by the way !
tubbutec
Steevio wrote:
One more question,
There will be a transpose setting for each channel. If you are looking for CV controlled transpose though without using a CV-in channel, you'll need to wait for the expander..
Steevio
OK thank you, I look forward to it !
Steevio
another question;
is it possible or will it be possible to create your own folder to save your own scales ?
I cant find anything in the manual about this.
Phil999
I believe one does create folders on the computer. Tubbutec recommends to organise scales in a tree structure with not more than about 50 scales per directory. See manual page 8.
Steevio
I meant can you do it on the screen.
Phil999
my guess is that you do such things on the computer. Once you have all the scales you want to use arranged on your card, you can leave the card in the module and continue working inside the module only.
tubbutec
Creating directories, moving, renaming and deleting files in the µTune file browser is on our TODO list, but not with the highest priority.
I also recommend creating the directory using a computer.
Steevio
I'd just like to ask a few questions to Tubbutec.
Do you have any idea when this is likely to happen ? near future or not in immedeate plans?
Also do you know when the expander is likely to happen ?
I'm only asking because because I have a bunch of gigs including a tour coming up later this year, and I'm currently configuring and rebuilding my live rig and I would like to use the µTune as a master Quantizer in the rig, and I need 4 channels and also it must be easy for me to switch between scales in the live setting without having to set the notes per octave everytime if I use exotic scales.
If these arent likely to be implemented in the next few months (before the summer) I will have to stick to my current quantizer set-up and practice in that way and save the µTune for a future rebuild and tour.
Thanks in advance, and I totally understand these things dont happen quickly and easily.. but I needed to ask so I can plan ahead..
tubbutec
Hi Steevio,
we are working on the software and the expander but it is always hard to estimate a date.
Expander developement is looking good so far, but still a lot of software work to do.
When we have finished the development of the expander, it can easily take 2 months till production has finished due to long wait times with assembly houses.
As much as I would like you to use µTune in your upcoming live setup, it is probably better to wait till the expander is really available.. sorry
Steevio
thank you for the info Tubbutec !
One last question, is it possible to calibrate the µTune ?
as from the output from both my Doepfer A155 sequencers I'm getting these results with the µTune set to 12 notes, and maximum clockwise turn on any step;
1 V/oct = 12
2 V/oct = 25
4V/oct = 50
with any of my other quantizers I'm getting the expected 12, 24, 48
At first I thought it was my A155 that needed calibrating until I found that you cant calibrate them, and then I tried my other quantizers and discovered that they were accurate.
can you help?
tubbutec
1 V/oct = 12
2 V/oct = 25
4V/oct = 50
can you help?
Hi Steevio,
which firmware version are you running?
Steevio
aha !
1.0
and HW17
Ive just read the website, thank you.
I didnt think it had been out long enough to be on an update smile
Steevio
OK so I hit a snag.
performed the firmware update, and everything seemed to work fine, it now reads FW1.01 on boot up, however it also says 'no SD Card' and there are no scales visable.
I removed the SD card and read it from my computer and all the scales are there.
any ideas ?
I also checked the calibration and 2V is ok at 24 but 4V is reading 49.
