Multiplier, Dual Multiplier
Discussion and Support for our Atmospheric Modification Devices.
Moderators: Kent, infradead, loss1234
calaveras
Post by calaveras » Sat Dec 16, 2017 6:37 pm
Picked up this kit from Mr.Snazzy at the Music Machines thing in Maspeth a couple months ago.
Really great balanced modulator/ringmod type of effect.
One thing I've found out in using the module, is that it really benefits from having a polarizing mixer next to it.
I used the WMD Invert/Offset. Which give you inverted and regular signals from your regular input. It also has this neat thing where you can CV control the offset, which works insanely well with the Multiplier.
If there is ever a MK II of this module, Dan you gotta put a couple offset generators on the front end. Esp if they can be under CV.
flx
Post by flx » Sat Dec 30, 2017 4:37 pm
Great tip! I just got a BiMix for my Snazzy System to play around with CV manipulation. When you say "next to it", do you mean for the Dual Mutliplier's inputs or outputs?
You can also find and contact me here:
tuesdaynightmachines@gmail.com
YouTube
Instagram
nightmachines.tv
Return to “SNAZZY FX”
