Thomas Henry's 2017 CEM3340 VCO MAXIMUS (PCBs/Panels)
MUFF WIGGLER Forum Index -> Music Tech DIY Goto page 1, 2, 3, 4, 5, 6  Next [all]
Author Thomas Henry's 2017 CEM3340 VCO MAXIMUS (PCBs/Panels)
fonik
URGENT:
i corrected a nasty error in the documentation! (page 6, R4 removed from table)
http://www.synthdiy.fonitronik.de/pdf/TH-VCO-MAXIMUS-doc-v1.pdf
__________________________________
Front panels and PCBs are now avilable:
https://www.thonk.co.uk/shop/fonitronik-th-vco-maximus-panelpcb/
If you want to know more about this projects history you may want to take a look here:
http://www.birthofasynth.com/Thomas_Henry/Pages/VCO_Maximus.html
TH-VCO-MAXIMUS by Matthias Herrmann, on Flickr
col
Ordered! Been eagerly awaiting this for a while, Thanks for all your efforts Matthias!
euromorcego
looks excellent!
will thonk be the only place that stocks it, or will be other retailers as well (maybe one that accepts eur instead of gbp)?
calaveras
kewl
dot matrix madness
cool
Is there also a separate schematic besides the BOM and build documentation available? (in particular for +/-12V supply)
PWM
dot matrix madness wrote:
cool
http://www.birthofasynth.com/Thomas_Henry/pdf/VCO_Maximus/VCO%20Maximu s%203.5.pdf
Maybe R4, R55 and R60 need a lower value for +/-12V operation.
Cablebasher
Hey Fonik
I see your BOM has different values depending on whether or not we use a TL431 for the Eurorack version.
Would you recommend using one or not? What are the benefits?
Can’t wait to start soldering!
dot matrix madness
cool
Do the designations (numbering of resistors) match to does in the build documentation? Anyway, the TL431 is not included.
AntonWoldhek
Cablebasher wrote:
Hey Fonik
2nd. The document currently doesnt explain what the pros and cons are of the options there are.
Looks a great project though. The design notes from Thomas Henry are amazing to read aswell. I wish more designers published those.
plushterry
Wicked. Many thanks to Mr Henry and the rest of the maximus crew SlayerBadger!
fuzzbass
Ordered! Thank you Matthias, I am a superfan.
fuzzbass
Wow made it across the ocean fast. Thanks Thonks.
LED-man
Great job, Matthias
Is there a chance to get only the pcbs ?
I want a MOTM version, maybe I design a control pcb to connect the jacks and pots in a easy way.
templar
Circuit PCB is available here: http://www.thonk.co.uk/shop/fonitronik-pcbs/
Cablebasher
Guys
Does anyone have a part number for the TL431?
It’s not something I’ve used before and seems to come in many shapes and sizes!
Also, are people building with or without a TL431?
Been waiting on a thru hole CEM VCO to happen for a while.
Great work Thomas, Scott, Fonik!
fuzzbass
Useful:
https://www.thonk.co.uk/wp-content/uploads/2017/12/TH-VCO-MAXIMUS-docu mentation-preliminary.pdf
Cablebasher wrote:
Guys
This one:
https://www.mouser.com/productdetail/stmicroelectronics/tl431aiz-ap?qs =sGAEpiMZZMvAvBNgSS9LqsykYh3aFdDN
Does anyone know the purpose and / or values of R26_B and R27_B?
skee
On the Thonk site the main BOM says R4=820R but the alternative says 3K omit, 4k7 or 10k. Am I reading this incorrectly?
fuzzbass
The main board is format independent. It can run at 12 or 15V. The BOMs you encounter are assuming 15V operation. Matthias added a provision for a voltage regulator for improved pitch accuracy. Its on the board, and optional parts for it are listed in Matthias' BOM. I have not yet found much documentation describing it.
So you can build this 12 or 15V, with or without the regulator. Those are the four cases listed in the table following Matthias' BOM.
This table still does not explain C1_B, R26_B or R27_B. hmmm.....
skee
Yes, I understand the purpose of the table, but none of the cases for R4 match the value on the main (15 volt version) BOM. Other resistors on the table do match. Is this a typo or is there another interpretation?
fuzzbass
Has anyone succeeded building this yet? I went with 12V BOM revisions as stated in Fonik's build doc, using the TL431 and I have a dead VCO. The CEM3340 is putting out no waveshapes (powered from either the TL431 or the +12V rail). The chip tests good outside of this circuit. There are a bunch of discrepancies between the TH published BOM and the build doc that Fonik wrote. There are components on the board that are not shown on the published schematic or Fonik's BOM. Seems like there are errors in the substitution table (R4?). I'm tempted to just put this away until the build doc gets sorted out.
[edit] Caveat: its entirely possible that I just made some stupid error in my build.
col
Mine hasn't arrived yet, probably held up in the Xmas post, heading to the outer colonies. zombie
Fuzzbass, yeah hold off for a bit or if you are a member of the http://electro-music.com/ forum you could go ask a question directly in the Thomas Henry forum. I'm fairly confident that you will get a decent response there.
fuzzbass
Yeah I did that already. I don't want to bother Thomas, I'm pretty sure the issue is with parts substituted or added in the Fonik design and his doc seems like a work in progress right now. I'm hoping Fonik releases a schematic that shows the circuit on his board with the optional regulator. I don't have my back to wall for VCOs right now, so I think I'll just wait for that or see what other wigglers find.
nobody
Can you run these at +/- 12V? I only have 12 on my rack, but a lot of these CEM designs (digisound, opencem, this), all have +/-15V supplies.
fonik
the documentation provides all info how to change values to have it running properly under 12V
fonik
URGENT:
Page 1 of 6
