Panel Mount Pushbutton for Eurorack
Author Panel Mount Pushbutton for Eurorack
thegrinch
Hi, I am looking for a cheap panel mount pushbutton for eurorack. I am already using Thonkiconn PJ301M-12(https://www.thonk.co.uk/wp-content/uploads/2014/02/Thonkicon n_Jack_Datasheet.pdf) which are soldered to the pcb and mounted to the faceplate. So I need something compatible with those measurements[/img].
Does anybody have a part they can recommend for this purpose. Precise part numbers, datasheets, and / or mouser links are greatly appreciated. Thanks!
ashleym
Momentary or latching? A lot of switch cut outs are larger than 3.5mm jacks.
FetidEye
these are cheap and have the same diameter as jacks:
http://www.taydaelectronics.com/electromechanical/switches-key-pad/pb- 11d02-push-button-panel-mount-spst-no-pb-11d02-th1r00.html
they are momentary switches
thegrinch
Thanks for your replies. I am looking for something momentary.
More so than diameter I am looking for something with a similar height to the thonkicon jacks so that both could be soldered into the pcb directly and mounted to the faceplate. It looks as though the ones posted by FetidEye will work for this.
AlanP
I've used those, panelmounted, same PCB as thonkiconns and Alpha 9mm pots.
The Tayda ones need some de-bouncing circuitry, though.
thegrinch
Looks like that one is out of stock. Seems like the kind of thing that won't get restocked any time soon so can you recommend another?
AlanP
Black and Green are still in stock. (Green is in a whole lot of stock.)
