Reverse power protection with MOSFETS!
Author Reverse power protection with MOSFETS!
E.A.S.
Here's a circuit I've adapted for some of my designs. Feel free to use it, or part of it for your needs. I first saw an implementation of this in a MAXIM app note.
This is a basic reverse power protection circuit using MOSFETs to provide the protection.
The advantage of using MOSFETs as opposed to a series diode is because you can choose a MOSFET with low Ron so there is VERY little (practically none) voltage drop,
as you would get with a diode, even a schottky.
How it works:
As you see the MOSFETs are connected "Backwards" with the power input on the DRAIN side rather than the SOURCE side. Not shown in the schematic is the "body diode" inside the MOSFET.
The MOSFETs are connected in a way that when correct power is applied, the body diode conducts, the SOURCE is now one diode drop down from the input voltage, and at a level relative to the GATE, to turn on the MOSFET,
this then bypasses the body diode, giving an OUTPUT near equal to the input. By choosing a MOSFET with very low On resistance, this voltage drop can be made to be practically zero.
On my circuit I've added an optional power led / reversed power led, in case you're feeling frisky.
The MOSFETs shown can supply over 1A (1.4A @ 25C) and are little guys. (SOT-23)
Normally for euro, If you are using a 16pin connector and reverse the connector, you will end up shorting the +5V, +12, and internal Gate bus to 0V.
Not good.
Another issue in euro arises when there is a 10pin header on the module and a 16 pin power cable is plugged in, is the possibility of plugging the power in with an offset,
once again shorting one of the power / bus connections to 0V.
My solution would be to use a shrouded 10 pin header. This guaranties, the connector can't be plugged in with an offset. Obviously this isn't perfect because
you only get used of the +- 12V rails. So if you need the CV, GATE or, +5V rail, you're out of luck.
That said, If you really need a +5V rail on your module, you can always locally regulate, down from the +12 anyway.
Basically, you can plug in the power reversed, and wont harm the module, anything else on the power rail, or the power supply itself.
It can also indicate (without smoke signals) when the power is reversed.
-Mike
imcmahon
clever!
kassu
Nice idea. I think I saw something similar on the EEVblog a long time ago, but I have a feeling it used more support circuitry.
Not good.
Hmm, got me thinking, quite a lot of things happen when you reverse a 16-pin connector (let's assume the internal CV and gate are not used)
- The busboards +5V and +12V are shorted together and connected to your modules ground
- Your modudes +5 and +12 are both grounded
- -12V is likely left floating on both sides
So for your module it means +12V and GND are reversed, which would be protected if there are diodes (or mosfets). But for the rest of the system still +5 and +12 are shorted together, and it depends on the power supply what will happen
- If you are lucky the PSU just explodes (or fuses blow)
- Or, if +5 is derived directly from +12, the 5V regulator dies (or is bypassed via a reverse current protection diode), and the 5V rail gets raised to 12V in the entire system. This will certainly kill any digital modules using 5V, potentially quite costly.
Jarno
More info here Geofex
E.A.S.
Not good.
Yeah, Ive been trying to think about different ways to fix this shorting together and grounding issue,
I think you could have a MOSFET switch on the two ground lines, that only switch on when there is correct power on the proper rail.
This might add a little bit of resistance the the return path though. depending the the fet used. Havent built it up yet though..
-M
E.A.S.
This adds protection to a 16pin connected module.
Adding to the prior design this adds protection for the power supply itself. Adding protection from shorting the +12 rail to 0V and shorting the +5 volt rail to 0V.
The only thing the circuit does not protect from is shorting the CV Bus output to 0V. Only an issue if:
1) you have modules that bus AND the the CV output circuitry doesn't have protection on its output. (perhaps rare for the circuitry synth modules would use to drive a CV bus)
other additions, would by some ESD protection for the MOSFETs.
a resistor in series with the gate and a small bypass cap from the gate to the drain.
-M
The circuit goes something like this...
E.A.S.
Added a little ESD protection for the MOSFETS..
-M
TheSlowGrowth
The trouble with very low Ron is that noise make its way into and out of a module more easily. The typical Schottky + 10Ohm + electrolytic capacitor arrangement may have significant voltage drop but it also acts as a simple lowpass filter for noise, in either direction.
latigid on
Check out Rossum's power supply solution:
http://www.rossum-electro.com/uncategorized/circuit-protection/
Some will complain that this increases the 0V supply resistance.
E.A.S.
Interesting. I actually thought to disconnect pin 9 and 10 as well, but was thinking the 5V would still short to 0V.. but in hindsight the with the (16pin) connector reversed the PSU 0V isnt connected to the 0V of the module so only the shorting is the +12 and +5 together.
I personally wouldn't worry too much about 2 of the 6, 0V connections not being connected.
The optional reverse power LED, only works when using the 10pin header.
E.A.S.
Which noise are you speaking of?
I guess there's nothing stopping you from choosing a MOSFET with larger Ron, if you really wanted. (or adding a resistor to your design.)
-M
trip
Using this very setup with; 10ohm resistor, 10u electro cap and S1JL diode I was getting a 600-700mv drop, which is pretty significant. There's no reason you couldn't replace the fuse in this schematic with a resistor (I guess f1/f2 are fuses?), and the 10u caps are already there.
Graham Hinton
You can't polish a turd. Why try?
Any half decent regulator will shut down when shorted to 0V. Common linear regulator ICs do this faster than a fuse can blow. The MOTM 4-way connector may sometimes be mated one pin out and all that happens is one rail is shorted to 0V and the other disconnected.
The problem with mixed analogue and digital systems is the +5V getting either analogue rail shorted to it and taking all the 5V ICs out. This is usually dealt with by having a crowbar circuit on the +5V, which is a power thyristor that triggers on the +5V being exceeded and deliberately shorts the rail to force the regulators to shut down. You have to turn off and fix the fault.
There should be circuitry on a module to protect the rest of the system from a fault on that module, but it shouldn't be trying to compensate for bad system design. Isn't it easier to just put a better connector on your own modules instead of perpetuating a mistake?
trip
Attached eagle library for sot-23 n and p mosfets, as yet untested but should be fine.
trip
The named mosfets in the schematic up top are out of stock everywhere atm with fairly long lead times - these parts seems to be superior as far as I can tell for the N channel:
https://www.mouser.co.uk/ProductDetail/Diodes-Incorporated/DMN3023L-7? qs=sGAEpiMZZMshyDBzk1%2fWiw4EkXjINyPrH7PGy3HZ4FBEKOATXpiIxA%3d%3d
and for the P channel:
https://www.mouser.co.uk/ProductDetail/Diodes-Incorporated/DMP3099L-7? qs=sGAEpiMZZMshyDBzk1%2fWi%252bzdcdBSapG%252bDctwa3X8OfU%3d
They cost a few more pence each than the other named parts, and have Ron of 25 and 65mOhm respectively.
Unless there's something I'm missing on the datasheet that would make them unsuitable?
hirada
For comprehension, would you please allow for two beginner questions?
1) What is the purpose of C1/R2 and C8/R3 respectively? Since they arrived with the added ESD protection: Discharge when somebody touches the case?
2) Why did you connect the source terminal of the p-mos to the module side and not the header/psu side?
Thanks for any insight
555x555
Is this actually borne out by experience, or just something that snuck its way into our collective thinking?
I did this analysis a bit ago: https://www.muffwiggler.com/forum/viewtopic.php?t=185331 which indicates that, basically, raising the resistance is *never* the right choice for a module's power inlet. I'm genuinely asking, though, because that analysis didn't involve real-world measurements, just theory.
Paul Perry
Bypass capacitance should overcome most potential problems caused by a small power series resistance - but analog modules are a special case, seeing that signals go down to zero frequency, almost. A properly designed module in which critical voltages are derived from reference circuits should be immune.
I agree that I would very much like to hear about real-world experience.
frijitz
neil.johnson
There are plenty of real-world examples out there. Go hunt out schematics for audio mixing desks (I have examples from SSL, Mackie, DDA, Soundcraft, Allen & Heath, Studer, ....). I'm not saying they're the very best circuit designs ever to grace the art, but even low-grade mixing desks are orders of magnitude better noise performance than the majority of synth modules.
Neil
555x555
OK, just checked out the SSL 1600 series schematics. The series resistor at least has a good pedigree! But as you say, just because the SSL consoles were very good doesn't mean they did everything right. Also, what we don't see in the schematic was *why* they made this choice. Could be bc it's lower-cost than a better solution. Could be to lower the start-up drain on the power supply. Etc.
Has anyone actually built a module without the resistor, then added the resistor and measured/heard a reduction in crosstalk or noise? That seems like the minimum experiment.
neil.johnson
Do you mean the Soundcraft 1600 desk?
http://forum.analogconsole.com/downloads/SoundcraftSeries1600_user_gui de.pdf
Neil
555x555
Oops, yes, that was the one. They use varying values but, for example, the input modules use 47 Ohm series resistors and 22u caps.
neil.johnson
Right, but now you need to understand why they used those values, what problems they were addressing, and what other decisions led to that design choice.
Also, a mixing desk is a very different environment to a modular synthesizer, especially of the Eurorack variety. So you can't just copy-paste from one design domain to another.
Neil
