Amplify a CV 200% with Voltage Controlled Attenuator
Author Amplify a CV 200% with Voltage Controlled Attenuator
stephenmendes
Here is a neat way to AMPLIFY a Control Voltage with a linear VCA (provided it's DC-coupled)
Put in a fixed voltage twice the maximum amplitude of your CV into the signal input..... put your CV into the CV input..... and the output signal 'follows' your CV but at twice the amplitude.
This is exploited in the following patch:
https://youtu.be/GGkrvyR0STs
ranix
I love your videos w00t
stephenmendes
Gee... thanks... that's real encouragement to make some more
flo
That will half-wave rectify your signal, though...
kindredlost
Good tip if you have no Q125 Signal Processor, and that's why I have six of them. If I had a small system I'd still have at least two of them. thumbs up
Dave Peck
Only if your CV signal is bipolar and your VCA has no 'initial gain' control. If it does have an initial gain knob, set it to 50% and the entire CV signal will remain intact, with 200% gain. Although it will also now have a positive DC bias, but that is easy to remove.
Even if your VCA has no initial gain knob, you can still make this work by adding a DC offset to the CV signal before patching it to the VCA, so it never goes negative. Then remove the DC offset from the output signal, same as above.
Rex Coil 7
Q114++ Mixer works pretty well for all of that type of thing as well. Very versatile module. I dig mine!
stephenmendes
Posted in wrong place..... can somebody tell me how to delete ? .... when I click on the edit/delete button it allows me to edit but not delete .... what gives ?
