Understanding the Moog Ladder Filter Schematic
Author Understanding the Moog Ladder Filter Schematic
thegrinch
Hi, I was looking at a schematic for the moog ladder filter and had a few questions about how to read it. I figured some of you may have looked at this in the past and could offer advice. Here is the schematic I am looking at:
http://experimentalistsanonymous.com/diy/Schematics/Filters%20Wahs%20a nd%20VCFs/Minimoog%20ladder%20VCF%202.gif
What do the numbers in circles refer to?
I assume emphasis is resonance. Can those two points simply be connected together?
What does amt of contour refer to? Is this a DC voltage? What is the rage of voltage input on the control node?
Are 8 and 3 simply a connection to -10 v on that transistor pin?
If anyone can answer this, or perhaps point me to a clearer schematic I would greatly appreciate it. Thanks!
guest
those are pins on connectors that go to other boards. you can find what they all connect to here:
http://www.fantasyjackpalance.com/fjp/sound/synth/synthdata/16-moog-mi nimoog.html#3
thegrinch
Okay, took me a minute to figure out but it seems Interconnecting Wiring Diagram has everything I need to know.
