ES3 Sync & Latency Behaviour
Author ES3 Sync & Latency Behaviour
Remote337
Os
Strange situation using Cubase on SW 2.4.
I use latency set to 128 and get about 3ms latency via a Fireface 800 when using Voice controller. All very acceptable.
However when using the Sync plug in to drive clock I have to set the offset to +100 and then it's smack on the beat. This setting doesn't seem to change even if I mess with the latency.
It doesn't really matter as it works just wondered if you had any idea why this would be the case?
