should i get the mixpre-3 or mixpre-6
Author should i get the mixpre-3 or mixpre-6
odditymedium
i make films and i thought if getting one of sound devices mixpre series. can you help me decide if the mixpre-6 is overkill?
reasons why i am leaning towards the mixpre-6 over the mixpre-3
- more inputs
- asterisk button to annotate
- locking XLR connectors
halp?
Gyroscope
Get the 6. Better regret having too much inputs than not enough. Is the price difference that big?
odditymedium
its about $200 more. but yeah i'm leaning towards the 6 too
Hovercraft
When the MixPre's were announced--I ordered a 3, but after thinking about potential uses--I switched to a 6, and it's worked out well. A friend just got the 6, and is swapping it for the 10T--haha. For the combo TS/XLR jacks alone--the upgrade is worth it.
lud
Do you guys record your music jams on these?
leeski
get the 6 as it has Sampling Frequency
44.1 kHz
48 kHz
96 kHz
192 kHz
And i do record my stuff to this lud
Hovercraft
Yes—one button recording—so nice and simple.
odditymedium
44.1 kHz
48 kHz
96 kHz
192 kHz
whats the advantage of having multiple sampling frequencies
leeski
odditymedium wrote:
44.1 kHz
48 kHz
96 kHz
192 kHz
Less jittery noise when tuning down
I read it from a sound designer interview which makes sense
odditymedium
what does tuning down mean
Hovercraft
I think the potential advantage to higher sample rates is recording sound effects that will be slowed down in post-processing. The idea is the samples have higher resolution, and are more likely to hold up to extensive processing. The caveat is the quality is dependent on your mic, recorder, recording technique, and methods of post-processing.
odditymedium
any other plus points of the mixpre-6
what do u folks ESPECIALLY like about it
odditymedium
also - where to buy the mixpre-6 in europe
grillo
It looks like musicstore.de has them now. Thomann has some sound devices stuff but not at all the new range.
lud
Can you do multitrack overdubs on the 6?
Hovercraft
MixPre doesn't do overdubs, punching in/out, etc.
Hovercraft
It's an audio swiss army knife--multitrack recording, mixing, USB interface. Pro-grade preamps, analog limiter, high quality headphone amp, incredible routing flexibility, super compact, great controls/interface.
odditymedium
what do you mean by routin flexibility
odditymedium
also, what about battery life? do y'all use it plugged in to power?
should i get the lithium battery pack extension?
or should i get a usb power bank
dropthedyle
you should get a usb powerbank !
NB: there is a cool fbook community of mixpre users here : https://www.facebook.com/groups/mixpre)
