Power Cable Header Eurorack
Author Power Cable Header Eurorack
jimfowler
Does anybody have a part number for 10-position (eurorack) female power connector housing and the associated female crimp terminal? I've spent 30 minutes scouring Mouser but can't be sure I've found what I need. I don't need/want it to be polarized. To be clear: I'm not using ribbon cable. I'm building cables ala Graham Hinton: http://hinton-instruments.co.uk/paprod/psu/cables.htm
Thanks.
- Jim
schenkzoola
Those are Mini-PV connectors, sometimes referred to as DuPont connectors.
Here are some DigiKey links:
10P - https://www.digikey.com/product-detail/en/amphenol-fci/65043-032LF/609 -2374-ND/1002689
16P - https://www.digikey.com/product-detail/en/amphenol-fci/65043-029LF/609 -2371-ND/1002686
You will need to buy the crimp contacts separately, and which one you use will depend on what wire you are using.
If you go to the product pages, DigiKey lists the pins in the "Associated Product" section.
jimfowler
That's exactly what I needed...thanks so much.
