VCO options for a beginner
Author VCO options for a beginner
Dextreme08
Hi all,
I am hoping to get some input on helping to choose my first modules. My main aim is to create bass samples to get back into my DAW for Drum and Bass production.
My plan is to get a few cheap modules (VCF, Env's, LFO's) and hopefully some simpler DIY modules, however due to the features I want I expect to have to pay the going rate for my VCO's.
My main requirements in order of importance are:
Linear FM - Exponential would be a nice bonus (thru-zero would also be nice, not sure whether i would need both thru-zero and standard?)
Hard sync
2 sawtooths - for classic reese basses!
Waveshaping - Would save an additional module I guess
AM - I assume i can get this using a VCA?
I have earmarked the following osc's however bonus points if I could get similar features for cheaper, they do not necessarily have to be a single unit.
The Harvestman - Hertz Donut Mk2 (not sure if digital is a drawback or not)
Make Noise - DPO (Probably my very upper limit on pricing unless something exceptionally sexual gets suggested)
Any suggestions are most welcome, I can't really get hands on experience anytime soon.
Thanks all,
modularblack
Why having a complex oscillator, when you can have 2 simple ones?
A Doepfer A-110-2 + a Make Noise STO will fit most of your needs.
Or an A-110-2 and the OSC form 2hp.
Or you switch the A-110-2 for an A-111-3.
When you grap two oscillators instead of one 500$ one, you also have enough money for a waveshaper or a VCA.
Dextreme08
No real reason! open to all suggestions, the A-110-2 does seem to fit most requirements. Is there any advantage to pairing identical oscillators? Coming from a non modular background it feels more natural to me.
R.U.Nuts
When you buy a DPO you get a waveshaper and three VCAs with it (maybe four VCAs when you count the wavefolder as well).
starthief
I would definitely go for TZFM rather than non-TZ linear FM.
And an argument for choosing a complex oscillator is they generally have extra utility stuff built in -- VCAs and attenuators for managing modulation, methods for tracking pitch between the two VCOs, wavefolding, etc. -- that you'd have to get separately if choosing two VCOs.
Hertz Donut mk2 will definitely hit all your checkboxes. It handles FM beautifully and easily. It's grittier than most options, by design, but cleans up pretty nicely if you run it through an LPG or lowpass filter. The waveshaping is also not exactly traditional, and it benefits from also adding a uFold or something along those lines. I find it really versatile and powerful though.
If going for separate modules, Rubicon+Dixie are a popular combination. They are based on the same core design and track identically.
With Doepfer I'd probably choose an A-110-6, or maybe the A-110-4, for TZFM.
modularblack
I like how different modules sound different and have different features, but maybe you just like one particular Oscillator very much and buy it twice only because its cool.
In the end this is a big decision of taste.
Dextreme08
Thanks for the input so far, I'm still no nearer to a decision! Although it does look like thru-zero is now a must have.
starthief wrote:
Hertz Donut mk2 will definitely hit all your checkboxes. It handles FM beautifully and easily. It's grittier than most options...
Dirt is definitely a positive!
I might have to look into the Rubicon+Dixie combination I had previously dismissed it due to cost, although not much more that the complex oscillators, i assume (incorrectly?) that I will need to add more to get them up and running.
Trebbers
The typically cited combo is Rubicon + Dixie + uFold.
TemplarK
The DPO is more than the sum of its parts. Its a extremely well designed and crafted module. I'm not sure if these "combo's" come close or not because i haven't tried but what the DPO gives you is something very special.
I love mine, took me personally a while to get to grips with it and be able to twist it to how i knew it could be twisted, but it was worth the patience really, its an amazing thing.
bradpickapiper
The octave switches on Intellijel oscillators are super useful!
uniquepersonno2
There's (theoretically) a new hertz donut coming out. Who knows when. But if that matters to you, now you know grin that said, I'd have started with a Loquelic Iteritas because it's absolutely fantastic, and would pair well with another oscillator like sinc iter (which both have sync).
Dextreme08
Being my first module, I imagine I will be forced to dive deep into it which is one of the reasons a complex vco is appealing.
That would explain why the donut seems to be out of stock everywhere!
beliefsystemrecords
The Intellijel Shapeshifter does almoste verything you want.
beliefsystemrecords
personaly i would probably get a rubicon 2 + dixie and a wavefolder.
peripatitis
so your goal is to record bass samples to use later in a sampler?
Joe.
It's not a complex VCO, but the e330 VCO from Synthesis Technology is pretty nice.
It's a budget VCO that will help you explore the options of the more expensive VCO's in Eurorack. It has 3 modes; A two operator FM mode, a Wavetable mode, and a 'Cloud' mode (which is 4x Saw waveforms).
Once you save up for a highend VCO it would go great fattening up the voice, either layered or pitched down an octave or two.
Another option is the Super Sawtor from Happy nerding, which will let you modify another VCO's output, turning it into that Supersaw sound.
Dextreme08
Correct. Eventually it would be nice to do other things but I'm starting with a limited scope!
Just another rookie
I may be speaking out of turn here so I apologise in advance for my stupidity.
I am new to modular. I started gathering parts mid December.
My vco is the Klavis twin waves.
Has FM, thru zero, lfo, soft/hard sync, etc. (One channel has a vca, so you can feed it from the second osc in lfo mode.......
Each Lfo can be (individually) externally clocked or not. With external clocking you can divide/multiply from the master.
VCO
Sine
Sqr/pulse
Saw/tri
Quad saw
Additive (even/odd/all)
Unison sqr/saw
Bit crushed saw/sine
Self sync sqr/pulse/saw/tri/sine
Ring mod
Noise (low-pass/bandpass/resonator)
Plus 7 lfo shapes.....a vco quantiser (16 scales)
Worth a look for £200.
It sure is a lot of fun but I for certain am not the hand of experience!
It’s actually pretty cool, I managed the firmware update via an iPhone. No problems. Its very simple to learn.
The only downside is, you have one jack on one oscillator only that is useable as a vca or thru zero or whatever, the second osc has all other features.
(V/Oct and parameter cv in)
It has some limitations but I found it to be a good starting block, you can pretty much coax most sounds from it. (Although it’s backed up by a few other modules!)
MarcelP
If you are initially going for bass then from my rack I would suggest a Furthrrrr Generator and a Rossum Evolution (Evolution has a really handy bass compensation facility for when you increase the Q). That combo plus a few EG and LFO, etc, will generate a wide variety of fab bass sounds - and a lot more besides when you move up the frequency spectrum.
Just another rookie
Marcel!
Your system is BIG!
Insane/nuts.....umm whoa!
esquilofreniko
Synthesis Technology E370 or E352
MarcelP
Just another rookie wrote:
Marcel!
Your system is BIG!
That’s what my kids think too! Yeah....a bit big and self indulgent, but there is a method to my madness. I started small but soon realised my “vision” of what I wanted to do necessitated a sprawling system of multiple modules. It’s my play-pit, safe place, sanctuary from work and a fantasy island made real. It does give some insight into the differences between types of oscillator and how different filters can shape sound though. I also realised the value of multiple simple module types as opposed to a few powerful multipurpose modules - it’s a trade off between hot satisfying fun and cold productivity (for me at least).
He_lium
Sorry for the maybe stupid question but what do you consider to be 3 VCAs in DPO?
starthief
I'd have started with a Loquelic Iteritas...
A lot of people have said Loquelic is sort of a mystery box... it sounds amazing but not really something you can learn a lot from. And while it's got two frequencies internally it's just the one output, so it's less flexible than something like Hertz Donut or Rubicon+Dixie.
It's something excellent to add later though perhaps smile
I have mixed feelings about that one. Unless the FM has changed a lot in more recent firmware versions, I found it nearly unusable (I'm an FM junkie). One of the FM algos was non-TZFM linear, and pretty weak; the other was... I forget what it was called, but sort of a TZFM alternate that was just sort of crazy IMHO.
I felt like its two voices did better on their own, or in unison. It does pack a lot of features into a small space, but I just didn't love its character overall. I think it felt too much like bread-and-butter VST synths rather than what I was looking for in modular.
R.U.Nuts
Two VCAs that control the FM-index: One for VCO A modulating VCO B and one for VCO B modulating VCO A (both share the same controls). And another one that controls the MOD index.
He_lium
Well yes of course smile Thanks R.U.Nuts
Dextreme08
That's one I haven't heard of before. I'll look into it.
MarcelP wrote:
If you are initially going for bass then from my rack I would suggest a Furthrrrr Generator and a Rossum Evolution....
The Furthrrrr does intrigue me (for the looks as much as the features!) although the Rossum Evolution would take it out of my price range at the moment.
I may have to try to get to a modular shop when I can to get hands on with all these suggestions as its looking like there is no definitive winner!
Alternatively I might just get where i can with cheaper doepfer modules until I get more of a feeling for what works for me...
dysonant
I have owned and sold my fair share of oscillators, both digital and analog. The first thing I will say is that the secret sauce can come from external modules, but that basic oscillator features are important. Much of that has been discussed here already in response to your requirements pretty clearly detailed in the OP.
One already mentioned that fits all of your requirements is the Hertz Donut MKII. It is an incredibly flexible module capable of clean and dirty sounds, but there is always a bit of aliasing, which in my opinion defines some of it's character. I've had it for probably three years and still discover new ways to use it. You should listen to it in person if possible, but I would say if you give it time and patience it will not disappoint.
Another already mentioned is the DPO. It does not have thru-zero FM, but as mentioned is extremely versatile and is many modules in one. There are many examples of it's sound online and several demos. It is fully capable of meeting the needs your described.
One that has not been mentioned is the E352. The new beta software has added thru-zero FM and it is amazing sounding. There is really no module comparable to it. While it only has two outputs, what you can do with wavetables, clouds and morphing provides and endless source of timbres.
Frankly, if I were buying my first oscillator now, it would hands down be an E352.
peripatitis
Well in that case i wouldn't go for a digital vco which have no real benefit over a computer sound source, especially in stepped workflow (meaning that you will be involved in sampling).
Personally i would focus more on the filters which can be a lot more usefull in a limited setup with few cv sources..
MarcelP
Evolution is just icing on the Furthrrrr cake - the FG works great as a stand-alone sound source and is (to my ears) less harsh than DPO, better in the bottom end.
The Doepfer option is good too - I especially like the sound of the thru zero oscillator - amazing value, the sound is not compromised by the price. Though bear in mind: it has been discussed on other threads that getting full Complex oscillator facilities (ie DPO) by assembling individual Doepfer modules could be more costly in the long run. That is my practical experience too - fun to do, ultimately hugely flexible, but costly in cash and space.
Joe.
This approach will allow the most flexible Complex oscillator in the end though (as long as you dont limit your self to Doepfer). There are soooo many varieties of wavefolders now for example, a 'built in' one will limit you to that sound.
The same applies to the VCO's you choose for the Carrier and a Modulator: having a variety of oscillators to chose from, 3 or 4, to build a basic 2 osc FM patch will allow so many different final sounds from effectively the same patch structure. (for example, I like FM'ing my E340 cloud generator, with a WMD Spectrum. but then other times a Spectrum & E330, or the E330 FM'ing the Spectrum, etc etc)
R.U.Nuts
So you could also buy a complex VCO and add another wavefolder and VCOs. Or two complex VCOs seriously, i just don't get it Of course four VCOs and two or more wavefolders offer more variety than a single complex VCO.
I'd like to argue that complex VCOs can be more flexible than a combo of seperate modules since it often require you to only twist some knobs to get a certain result while the same thing requires you to repatch your setup of seperate modules.
dysonant
I tend to agree with you on the point that a complex Osc is special in ways over the individual modules. For example patching the follow circuit on the DPO would require even more than just your basic modules, not to mention the normalizations from VCO B to all the stuff in the timbre section. However, I disagree with the statement that it is more flexible than a combo of modules. Yes, you may have more flexibility to quickly modify a patch simply by turning knobs, but it also lacks the openness of individual modules. There are many times where I would like to tap into the wavefolder on the DPO and I cannot.
On the main topic, somehow this has become a conversation about complex oscillators, which is fine, but I still suggest the OP take a close look at the E352. If this is the beginning of you "going modular" it can be the foundation upon which you build.
starthief
Double Helix has inputs that let you feed anything through its wavefolder and LPG. It would have been nice if the folder/LPG were separate, and if there was a crossfade control for the two inputs rather than a summing mixer, but it gets the job done.
Really just adding a wavefolder to any existing complex oscillator should give you all the flexibility of separate modules. And now you have TWO folders to play with. smile WIth a uFold added, I've never felt stymied by any limitations of my Hertz Donut or Double Helix.
But I think there are no wrong answers here; it all comes down to personal preference.
E352 is an interesting suggestion. There's 2-OP FM mode, a phase modulation mode which works nicely, a wavefolding mode, and an FM input that's now switchable between expo and linear TZFM. You'd want to add another (probably relatively simple) VCO to take advantage of all of it.
Personally: my three most used VCOs in order are E370, Double Helix, and Hertz Donut. All of them are quite versatile, but I tend to use each more for the things they naturally excel at, only occasionally doing things "the hard way" grin So for dynamic linear TZFM I usually turn to Hertz Donut; for dark and woody and round West Coast stuff I go with Double Helix; for enormous pads, massively complex drones, or for individual "simple" VCO/LFO duties I tend to choose E370.
Dextreme08
The conversation about complex vcos is part of what made me make the original post as they seemed to solve a lot of my requirements.
The E352 to me looks very close to still being 'in the box' with knobs on, especially as the most used VST's right now are wavetable synths. However with this many people recommending it, it's definitely worth a look. Hopefully I will get a chance to see one in the wild soon
Eurtrude
Did you take a look on full voices, like the SE Tonestar ? It's very well featured : 1 super fat osc with mixer on différent waveforms + sub - 1 gorgeous vcf with distortion - 2 env. - 1 vca - 1 lfo...
You could then add an another cheap osc (doepfer) for fm sounds and a wavefolder ?
The demos I heard from the Tonestar 2600 were amazing, especially for bass.
[video]http://www.youtube.com/watch?v=Ds0ftMQBeXI[video]
racooniac
+1 for the rubicon2 & dixieII+ & wavefolder combo
its analog and it can be as simple or complex as you want it to be.
to make it "fat" just add the right filter and experiment with saturation/distortion on various points in the signal chain.
peripatitis
That's a good idea, another perhaps might be this:
https://www.modulargrid.net/e/steady-state-fate-bantam-prototype-silve r
but i don't know when its coming out..
Eurtrude
Oh God... always more ! screaming goo yo
Thanks for the link, didn't hear about it !
