Updating Power brickPSU
Author Updating Power brickPSU
hippasus
A while ago I got one of these
frames that use two external AC/DC converters at 15V. Inside the case there are regulators for +-12V. I use the case for diy projects (my main system is properly powered). I would like to update the power bricks changing to only one at a proper switch and keeping the inside electronics (maybe except of course that way of generating the negative rail).
I was thinking on one of the erica 1.25A psu-skiff-case, but that as bit expensive since the case is otherwise working. Other option will be a mean well at +-15V but the output currents are a bit low.
Do you have any suggestion or idea?
