Specifically: about the MatrixBrute WITH Eurorack combo
Author Specifically: about the MatrixBrute WITH Eurorack combo
m127
Wondering if there are any current users of the MatrixBrute + Eurorack combo.
I'd just like to know about direct experiences with attempted integration and/or current drawbacks re this combo.
I read elsewhere about a +V only limitation? Is this right?
Also read there that voltages must be a max. of 3.5V when feeding the MB... is this right?
How do you like this combo overall?
I was looking into having both for generating texture-rich patterns. You know, clock them together, control the drifting, setting up multidimensional, generative chaos by exploiting the more traditional yet very hands-on approach of the MB together with some heavy, avantgarde stuff done with the more esoteric euro modulation and polyrhythmic capabilities via euroracks.
Thing is, I want a sure shot, because the MB would be a 2000$ hit or miss. Must make it a hit no matter what, or simply desist.
m127
No one is using the MB with eurorack, for real?
m127
There has to be someone...
concretic
I did use it with eurorack... Clocking externally from system - works well, everything can be synced with just a CV clock. Mixing voltages in matrix, works well. Playing 0coast as a 4th oscillator with all the control - works really nice.
Never had any issues with higher voltage into it, and yes it sends only +V according to the matrix and which parameter you control and how much (there is an attenuverter for that)
