Psychedelic tracks - Dark rythmic jams - 2 new tracks
MUFF WIGGLER Forum Index -> Your Tunes Here
Author Psychedelic tracks - Dark rythmic jams - 2 new tracks
Tago Mago
[s]https://soundcloud.com/essais-modulaire/chrysaor-9[/s]
[s]https://soundcloud.com/essais-modulaire/chrysaor-6[/s]
 [s]https://soundcloud.com/essais-modulaire/chrysaor-2[/s]
VOICES
1/ E350 (bass) EG : Ladik Gate : Ober X et Y
2/ FMVDO out 0 (lead) ----- QUAD VCF (2) ----- A138m (2) ----- DAW 2 + delay send
EG : MST 2 Gate : Ober Y
3/ CLOUDS (in 1 : SD / in 2 : mystery (part of HH) -------- VCA4p (4) ------- DAW 3
4/ DELAY --------- DAW 4
5/ HH : Mysteron + FM Aid (FMVDO -90 + QPLFO mix + A106 res) --- MVP 1/2 ----RYO Aperture ---- DAW 5
6/ SD JUPITER osc 1 + A110-4 --------- MVP 3 et 4 ---------- Lxd 2 -------- DAW 6
EG : ASYS (Lxd 2 cv) GATES : KNIT B / C / E ------- Doepf Switch
7/ BD --- E440 ---- Lxd 1 ----- DAW 7
EG : MST 1 --- MYST excite 1 + Lxd 2 cv GATES : KNIT D / E / F ------- Sputnik Switch
8/ DERVISH DELAY (for snare)
GATES
Ober X ---- JORANE c bass --------- LADIK ------- QUAD VCA (1) ------ A138m (1) + delay send ---- DAW 1
Ober Y ----- JORANE d bass --------- LADIK ------- QUAD VCA (1) ------ A138m (1) + delay send ---- DAW 1
------ Switch Mult (1) lead --- MST (2) ----- QUAD VCA (2) ----- A138m (2) + delay send ---- DAW 2
Ober 16ths ---------- TURING -------- A152 (4) ------- lead
---------- Ck Divider ------- /16 : (A166 (2) avec Knit C) (et OR --- Switch Mult 2)
------- /64 : Trig des 3 switchs (A-152, A-151, Sputnik)
---------- KG ---------------- HH
---------- Knit ---------------- BD + SD
Knit B ------- Switch 151 (1) SD ---------- Asys EG ----------- LxD (2) -------------------------- DAW 6
Knit C ------- Switch 151 (2) SD ---------- Asys EG ----------- LxD (2) -------------------------- DAW 6
------- A166 (2) (+ /16th) lead --- Switch Mult (2) --- MST (2) -- Quad VCA (2) ---- DAW 2
Knit D ------- Switch Sput (a) BD -------- MST (1) ------------ LxD (1) --------------------------- DAW 7
Knit E ------- Switch 151 (2) SD ---------- Asys EG ----------- LxD (2) --------------------------- DAW 6
------- Switch Sput (b) BD --------- MST (1) ----------- LxD (1) ---------------------------- DAW 7
Knit F ------- Switch Sput © BD ---------- MST (1) ------------ LxD (1) --------------------------- DAW 7
A166 (2) ---- Switch Mult (2) lead ------- MST (2) --------------------------- Quad VCA (2) --- DAW 2
PITCHES
Ober A -------------------------- JORANE (a) ------------------ PENROSE ------- bass
Ober A + B (Shades) -------- A152 (2) ---------------------------------------------- lead
Ober B -------------------------- A152 (1) ---------------------------------------------- lead
A152 (3) et VCA4p (1) ----- Shift Uscale ----- lead
Ober C ------------------------- JORANE (b) ------------------- PENROSE ------ bass
TURING ----------------------- A152 (4) ----------------------------------------------- lead
SWITCHES
A-152 ---- lead pitch (1 à 4) + dig outs (3 et 4)
A-151 ---- SD gates
Sputnik ---- BD gates
Jorane A et B (2 pitchs) bass ----- Penrose
C et D (2 gates) bass ----- LADIK -------------- QUAD VCA (1) -------------------------- DAW 1
Switch Mult 1 lead ---- Ober Y gate ------------------------------- MST (2) --- QUAD VCA (2) --- DAW 2
Switch Mult 2 lead ---- A166 (2) (OR of KG © + /16th) gate -- MST (2) --- QUAD VCA (2) --- DAW 2
QPLFO 1 : Delay Time + Dervish FDBK + VCA Matrix
QPLFO 2 : CLOUDS density
QPLFO 3 :
QPLFO 4 bi : Delay Fdbk + (inversé avec A-166 (4) ---- KG pulses)
VCA MATRIX
In 1 : FC LFO / In 2 : JUP Out I / In 4 : QPLFO 1
Out 1 : E350 MorphY / Out 2 : E350 MorphZ / Out 3 : CLOUDS size + FMVDO ratioCV / Out 4 : JUP cv2 + CLOUDS position
VCA 4P
1 In : MVP offset Out : shift Uscale CV : A152 dig out 3
4 In : CLOUDS out Out : DAW 3 CV : lfo ???
A166 (1) ---- PEG 1 ----- RYO Klang (OH) ----- DAW 5
A166 (2) (QPLFO 4 inversé) ---- KG pulses
MODULES USED
Ober = Oberkorn
Knit = Knit Rider
KG = Knight's Gallop
A166 = Doepfer A-166
Switch 151 = Doepfer A-151
Switch 152 = Doepfer A-152
Switch Sputnik = Sputnik Selector
Switch Mult = Doepfer A-182-1
Jorane = Joranologue Switch 4
A160 = Doepfer A-160 Clock Divider
Penrose = quantizer
Uscale = quantizer
Ladik = C-214 EG
MST = Synthrotek MST Dual Envelope
Asys = Analogue Systems RS-60 EG
VCA4p = Bubblesound VCA4p
QUAD VCA = Sputnik Quad VCF/VCA
RYO = RYO Aperture
JUP = Jupiter Storm
E440 = Synthesis Technology E-440 filter
MVP = Manhattan Analogue Manual Voltage Processor
LxD = Make Noise LxD
A106 = Doepfer A-106-6 XP VCF
QPLFO
FC LFO = Frequency Central Ultra Wave
A110-4 = Doepfer A-110 4 QZVCO
Mysteron
Frequency Central System X envelope
Clouds
FM Aid
Make Noise Function
Doepfer A-138
Doepfer A-138m
Mutable Instruments Shades
Turing Machine
Tago Mago
[s]https://soundcloud.com/essais-modulaire/mars-18-b[/s]
One take, no overdubs. Basic EQ on daw.
Tracks:
FMVDO : percussion (hh)
Rings : percussion
A110 : percussion (bd)
E350 : bass
Mysteron : Mysteron
Chronoblob
Tago Mago
Mysteron is the lead. No filter or fx.
Rythm is a loop I took on the net.
[s]https://soundcloud.com/essais-modulaire/mysteron[/s]
Tago Mago
5 tracks in one take, no overdub except a kick every 2 measures added on DAW : FMVDO - E350 - Rings - Jupiter Storm - Chronoblob
[s]https://soundcloud.com/essais-modulaire/dark-rythm-9b[/s]
[s]https://soundcloud.com/essais-modulaire/dark-rythm-9a[/s]
Tago Mago
To be more precise, there is a global reverb on the DAW, and, even if those tracks are recorded in one take, I did cut the parts I didn't like.
An important thing about this patch is the relation between FMVDO and E350:
Out-90° FMVDO output goes to E350 sync and Z E350 output goes to FMVDO PW/AM CV
(Out-0° FMVDO and XY E350 being the main outputs)
So when I change a wave on one oscillator, the other oscillator is affected, and vice and versa.
You can hear the E350 on the left and FMVDO on the right.
[s]https://soundcloud.com/essais-modulaire/dark-rythm-11b[/s]
[s]https://soundcloud.com/essais-modulaire/dark-rythm-11a[/s]
