Pittsburg Modular Lifeforms SV-1 and Korg SQ-1
Author Pittsburg Modular Lifeforms SV-1 and Korg SQ-1
doctorupdonk
Just got my first modular synth today, went for the Lifeforms SV-1 instead of Mother-32. I think i made the right choice!
I am using the cv and gate from a Beatstep Pro, which works perfectly, but
can't seem to cv/gate signal when i swap the same cables into the SQ-1.
I tried using the different voltage amounts available on the SQ-1 without luck.
Any thoughts?
hinterlands303
I think I would need more info to understand what is going wrong. Are you sending one of the sq-1 gate outputs to an envelope gate in and the cv output to your 1v/oct input? Do you have gates active on the sq-1? Is the sequencer playing? What kind of cables are you using? A picture might help.
The SQ-1 should work fine so either there's some user error or something wrong with your unit. It's most likely the former but you never know.
needlz
Any examples of use?
recoveryeffects
Can you post a Soundcloud link?
emptyvessel
did you figure it out?
BenA718
When you press the Function button on the SQ-1, is the 1V indicator lit?
