Best DSLR & Video Cams for capturing live in 2018
Author Best DSLR & Video Cams for capturing live in 2018
Sorry if this has been asked before but I couldn't find any threads using the search function.
I'm looking for a good camera for capturing videos of jams & live performances. Could be a DSLR or a video cam, doesn't have to be compact but must cope with low light and preferably be capable of capturing sound either directly (line in) or syncing with an external recorder.
I have many years of experience with DV cams and older digital systems so have a good grasp on the concepts, but haven't followed along or used any video gear / SW for the past 15 years or so...
What are you using? Any tips or recommendations for what to buy in 2018?
As a filmmaker it all depends on your budget. But if you're serious about it, I would recommend a Canon C100 MK2. It has good low light and 2 XLR inputs and a 3.5mm lead input too. It also has it's own audio mixer on-board. It can be overwhelming with all the settings and stuff, but I recently acquired one and it's amazing.
There's also the Sony a7s, which is probably the best low-light camera that exists at the moment, but I don't know what the audio capabilities are like because I've not used it before.
What lens you use matters too. For low light, you essentially want a lense with the smallest f-number (e.g. f2.0) and I wouldn't recommend using Autofocus. Set your focus manually beforehand, then forget about it!
If you don't mind having to sync up audio in a video editor, then get the a7s, but if you are wanting something that's flexible, go for the C100 MK2.
Also, a tripod. Everybody hates camera shake.
