Sensible 4PDT switch
Author Sensible 4PDT switch
windspirit
Hey, I am looking for a 4PDT switch (board mount) that is usable. I ordered some of these switches ( https://www.digikey.com/products/en?keywords=679-1858-ND ) which are exactly what I want EXCEPT that the actual slide switch is super short and it will not reach the panel (its about 7.5 mm tall). The part needs to be a little over a centimeter tall to even reach the panel, much less protrude from it a reasonable amount.
I know that I can just use an SPST switch with a switching IC to approximate the behavior but I have a few designs where this switch would come in particularly handy and so I want to find a mechanical switch that does this. Before I go diving into the parts space I figure that I would ask here and see if anyone has found a good switch that does what I need here.
Thank you!
search64
Voila, 12mm
https://www.digikey.com/product-detail/en/te-connectivity-alcoswitch-s witches/1825266-1/1825266-1-ND/1202301
windspirit
Not currently in stock, might be able to find it somewhere else.
I found this which looks like it will work, I can report back when I get some in case someone searches and comes across this topic.
https://www.mouser.com/ProductDetail/TE-Connectivity-Alcoswitch/MSS420 004?qs=%2fha2pyFaduj85nyowNgXfZCvKS%252b3faAp1ZYnolrhXxE%3d
Revok
Here you go: https://www.onlinecomponents.com/te-connectivity-amp-brand-18252661.ht ml?p=10269216
guest
does it need to be a slide switch? would a toggle do?
