Ardcore - trying to load my first Template
Discussion and Support for our Atmospheric Modification Devices.
Moderators: Kent, infradead, loss1234
globalwm
Post by globalwm » Thu Mar 29, 2018 1:54 pm
Machine: OSX 10.11
Downloaded and installed Dev software and 2.4.2 driver.
Selecting Board: Arduino/Genuino UNO (from Tools menu)
Selecting Port: /dev/cu.Bluetooth-Incoming-Port (the only one that appears) <<< this appears to be my issue.
Loaded a sketch: AC01_Template
Upload
Archiving built core (caching) in: /var/folders/k3/vjzx3f957r5fwbjvd9j1h_980000gn/T/arduino_cache_313785/core/core_arduino_avr_uno_51f02b7210b938436b779d1c032618e1.a
Sketch uses 3028 bytes (9%) of program storage space. Maximum is 32256 bytes.
Global variables use 220 bytes (10%) of dynamic memory, leaving 1828 bytes for local variables. Maximum is 2048 bytes.
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.Bluetooth-Incoming-Port -b115200 -D -Uflash:w:/var/folders/k3/vjzx3f957r5fwbjvd9j1h_980000gn/T/arduino_build_411833/AC01_Template.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/globalem/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.Bluetooth-Incoming-Port
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Looking at the Doc referenced above, I may have an issue with my Port? The Troubleshooting doc states:
"On the Mac, the serial port should be something like /dev/tty.usbmodem621 (for the Uno or Mega 2560) or /dev/tty.usbserial-A02f8e (for older, FTDI-based boards). "
Any ideas?
flx
Re: Ardcore - trying to load my first Template
Post by flx » Sat Mar 31, 2018 6:31 am
Yes, that's an issue. Reinstall Arduino, reinstall the FTDI Drivers (make sure you downloaded the correct ones), restart your computer and try it again.
EDIT: I attached the FTDI driver I recently installed on my Mac to this post.
You can also find and contact me here:
tuesdaynightmachines@gmail.com
YouTube
Instagram
nightmachines.tv
globalwm
Post by globalwm » Sat Mar 31, 2018 8:47 am
flx wrote: Yes, that's an issue. Reinstall Arduino, reinstall the FTDI Drivers (make sure you downloaded the correct ones), restart your computer and try it again.
Thank you! I did install 2.4.2 and when that didn't work, I took to looking online for a solution and then found out that in news versions of OSX, Apple starting including a FTDI driver that may be computing with this one. It is loaded in /System/Library/Extensions folder instead - which is protected.
I then tried renaming Apple's built-in FTDI (AppleUSBFTDI.kext) driver (using crsutil disable commands issued in recovery mode), rename the file with extension from: .kext to: .disabled and the turning back on with csrutil enable) in Recovery Mode using the Terminal.
See this thread for reference:
https://superuser.com/questions/1135730/how-to-release-reset-serial-port-ftdi-devices-mac-osx
Question 1: What version of OSX are you on? I'm on 10.11 (El Capitan) and from what I have researched online, many other people are having this issue with their Arduino boards universally (not just SnazzyFX users).
Question 2: Did you install the driver first before the Arduino Developer App? Does that even matter?
Thank you again - I think I'm close. I just want to take a break before I attempt again.
ps. There was also a hint that some boards were manufactured in China and required a different driver - I explored that route too and it was a dead end that resulted in my machine not booting and had to reinstall the OS in recovery mode.
flx
Post by flx » Sat Mar 31, 2018 2:14 pm
Hm, I'm running Sierra 10.12.4 and when I had the issue once, I just reinstalled everything and it worked.
YouTube
Instagram
nightmachines.tv
globalwm
Post by globalwm » Tue Apr 03, 2018 1:12 pm
flx wrote:Hm, I'm running Sierra 10.12.4
Curious, can you run this statement:
ls -l | grep USB
from these two directories?
/Library/Extensions
for me?
Thank you....
flx
Post by flx » Tue Apr 03, 2018 1:32 pm
Sure
/System/Library/Extensions :
AppleMIDIUSBDriver.plugin
AppleOSXUSBNCM.kext
AppleUSBACM.kext
AppleUSBAudio.kext
AppleUSBCDC.kext
AppleUSBDMM.kext
AppleUSBDisplays.kext
AppleUSBECM.kext
AppleUSBEEM.kext
AppleUSBEthernet.kext
AppleUSBEthernetHost.kext
AppleUSBFTDI.kext
AppleUSBMultitouch.kext
AppleUSBNCM.kext
AppleUSBNetworking.kext
AppleUSBTopCase.kext
AppleUSBWCM.kext
AppleUSBiBridge.kext
IOUSBAttachedSCSI.kext
IOUSBFamily.kext
IOUSBHostFamily.kext
IOUSBMassStorageClass.kext
IOUSBMassStorageDriver.kext
/Library/Extensions:
BJUSBLoad.kext
CIJUSBLoad.kext
FTDIUSBSerialDriver.kext
YouTube
Instagram
nightmachines.tv
globalwm
Post by globalwm » Tue Apr 03, 2018 1:44 pm
flx wrote: /System/Library/Extensions :
AppleUSBFTDI.kext
Interesting to see both drivers co-existing.
Ok, I think I need to find Arduino's Preferences file and purge everything and install again.
Thank you (again)
flx
Post by flx » Tue Apr 03, 2018 1:45 pm
Thank you (again)
No problem, let me know how it goes.
YouTube
Instagram
nightmachines.tv
globalwm
Post by globalwm » Sun Apr 15, 2018 10:32 pm
flx wrote: No problem, let me know how it goes.
I manualy purged the prefs file (and the install folder) and started again. I also installed on another Mac (also running 10.11) but still no luck. I can see the new driver installed though in: /Library/Extensions:
MacBook-Pro-13:Extensions anthony$ pwd
/Library/Extensions
MacBook-Pro-13:Extensions anthony$ ls -l |grep USB
drwxr-xr-x 3 root wheel 102 May 9 2017 FTDIUSBSerialDriver.kext
When I do this, I have the Ardcore in my lap connected via USB cable (I have tried three different cables also). Does it need to be racked and hooked up to Eurorack power? I read that when you connect via USB, that disconnects.
The new driver, though present, appears not to be loaded:
MacBook-Pro-13:Extensions anthony$ kextstat | grep FTDI
<nothing>
Manually loaded it displays:
MacBook-Pro-13:Extensions anthony$ sudo kextload /Library/Extensions/FTDIUSBSerialDriver.kext
164 0 0xffffff7f82fd9000 0x7000 0x7000 com.FTDI.driver.FTDIUSBSerialDriver (2.4.2) E16D9540-AF63-36AD-94C4-B1164FBD6078 <135 41 5 4 3 1>
However, when I launch the IDE, nothing displays but the “Bluetooth-Incoming-Port” - which is the only driver loaded in /dev/:
MacBook-Pro-13:Extensions anthony$ cd /dev
MacBook-Pro-13:dev anthony$ ls -l |grep cu
crw-rw-rw- 1 root wheel 17, 1 Apr 1 06:47 cu.Bluetooth-Incoming-Port
flx
Post by flx » Sun Apr 15, 2018 11:14 pm
globalwm wrote: When I do this, I have the Ardcore in my lap connected via USB cable (I have tried three different cables also). Does it need to be racked and hooked up to Eurorack power?
I actually do have mine racked an powered by the Eurorack PSU. :eek:
YouTube
Instagram
nightmachines.tv
globalwm
Post by globalwm » Wed Apr 18, 2018 8:52 pm
flx wrote:I actually do have mine racked an powered by the Eurorack PSU. :eek:
Well, I gave up - might have had a defective unit since it was purchased from a retailer as a "demo" unit. No lights, nothing when plugged in.
I worked with their Tech Support and after I described everything that I did and followed their instructions - they offered to issue me a return for credit. So off it went today. :(
I really liked the idea of this unit but sad that I couldn't get it to respond. I learned a few things along the way which is good though.
Thank you for the assistance and trying to step me through using this module.
flx
Post by flx » Sun Apr 22, 2018 11:25 am
Oh no! That sucks. Are you going to get another one?
YouTube
Instagram
nightmachines.tv
Return to “SNAZZY FX”
