What size screws for mounting MOTM modules?
Author What size screws for mounting MOTM modules?
Ekofisk
Like the title.
Sorry for this obvious question, but I couldn't find any answers using search.
rafe127
I assume you are asking about the 19A rack rails?
I was wondering this myself, just the other day... I don't know the answer.
-R
SepticUnderground
if i am not mistaken:
8/32 x ¼" screws
from: http://www.wiseguysynth.com/larry/flatrail/flatrail.htm
Bryan B
I concur, MOTM uses 8-32 for the panel mounting. That is a machine screw for mounting to a metal rail.
I would use a wood screw or sheet metal screw for mounting to a wooden rail.
nerdware
I don't know the size, but I got mine from Bridechamber.
Yes, Septic and Bryan are correct! It's in the MOTM FAQ too! "The mounting holes are drilled for #8-32 screws" thumbs up
http://www.synthtech.com/motmfaq.html
Pozor
This may be a cheaper option than getting them from the States: http://www.modelfixings.co.uk/unc_button_heads.htm . They're in the UK, good guys.
synthetic
Bridechamber sells them for cheap, great deal.
paults
They are 8-32 x 3/8" Phillips pan head black oxide. Try Aaron's Hardware.
Ekofisk
Thanks a lot for all your help!
